586,112 active members*
3,182 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco BMC 25 Ultimax2, HELP, HELP.
Results 1 to 6 of 6
    Aug 2007
    22
    Hello. At Me milling cutter HURCO BMC-25 CNC Ultimax 2. Have by transportation disconnected the panel of the operator, and wires of a food have not noted. All wires of black colour, that where is not clear. On wires +5, +12,-12, +24 Prompt that is connected on plugs TB52, TB54.
    Jun 2008
    1104
    The wires may be all black but they have numbers on them. put them in the connector on the back centre of the board matching the numbers up.
    Aug 2007
    22
    Unfortunately marks on wires are not present.
    [QUOTE=bloke;741671]The wires may be all black but they have numbers on them. put them in the connector on the back centre of the board matching the numbers up.[/QUOTE
    Unfortunately marks on wires are not present.I Have measured pressure of a food on these wires. I have already found where is connected +5, +24. I do not know where to connect +12volt,-12volt
    Jun 2008
    1104
    from left to right:
    0v
    +24v
    0v
    0v
    -12v
    +12v
    +5v
    +5v
    Aug 2007
    22
    Quote Originally Posted by bloke View Post
    from left to right:
    0v
    +24v
    0v
    0v
    -12v
    +12v
    +5v
    +5v
    Thank you very much. the Panel of the operator has earned. You know than differs CNC Ultimax from Ultimax2. By sight, they identical. At Me Ultimax. Best Regards.
    Aug 2007
    22
    Hurco_Latvija
    Hello You helped me, HURCO, thank you. I have more questions. I put an extra (Dual axis board). The menu appeared (5 axis present) but I do not see the values ​​of the coordinates of A, B. Advise where you can get Service manuals and shematic diagram HURCO BMC25, Ultimax2, CRP2. The value of first name and parameters. I want to connect additional A, B, axis. Best regards. ([email protected])
  1. HURCO BMC 20
    By PCM in forum HURCO
    Last Post: 06-05-2014, 03:07 AM
  2. Replies: 2
    Last Post: 01-06-2010, 12:26 AM
  3. hurco,bob-cad
    By dlshirley in forum HURCO
    Last Post: 03-05-2009, 10:39 PM
  4. Hurco KM-1
    By dafowfidy in forum HURCO
    Last Post: 03-05-2007, 07:54 PM
