Ordered the new mill on 1/29. Delivered by UPS last Tuesday 2/23. That day I was only able to uncrate and hoist onto stand with shop crane. The machine itself was pristine with no damage whatsoever, despite a few minor gashes in the crate. The stand, which is shipped in a cardboard box, did not fare quite so well. The door on the stand was a bit tweaked, would not close properly, and required some persuasion to bend the "hinges" so it would close. Nothing bad enough, for me at least, to require replacement.
This weekend spent time doing the cleanup, break-in, and set-up. Machine seems really nicely made and I am very pleased with the build quality. When I did the spindle break-in, I observed the same behavior that Hoss documented in his break-in video. I don't think this is a problem, just the way the design works. Specifically, the direction switch has to be in either the F or R positions (not the middle, neutral position) when you push the green "on" button in order for the motor to come on. Pressing the green on button when the direction switch is in the middle position will not turn on the motor.
I initially planned to bolt the stand to the garage floor, but after fooling around with shimming to level and seeing what a pain in general it was going to be to bolt it down, I have decided to go with the machine mount approach as described in the manual as one of the recommended options. I have 3" diameter ones on order from Grizzly. This will make it much easier to level, will help damp the system, and I believe will make for an overall better install on my garage’s concrete floor.
It was when I tried to install some R8 tooling that I ran into drawbar problems. I had purchased an R8 collet set from Enco and the G0704 comes with a B16xR8 arbor and drill chuck. No matter what I tried, I simply could not get the drawbar to engage in the threads of any of the collets or the arbor. I hesitate to reveal how long I struggled to make this happen. I was very careful in making sure the internal taper of the spindle was clean, there was no debris, etc. I tried gently tapping the arbor (w/o chuck installed) with a dead blow hammer to push it farther up into spindle, etc., etc. No luck.
The drawbar is a captive design and, initially, it was not clear to me how to remove it. It is actually very simple- just unscrew the “retainer cup” (ref 246-2) from the spindle, while holding the spindle’s lower portion with the hand. The drawbar can then be removed from the top. After removing, I verified the drawbar threads did engage just fine with the collets and arbor. I then put a collet in the spindle and inserted a thin piece of aluminum rod stock into the spindle from the top to use to determine the distance from the top of the spindle to the start of the threads in the collet. I then compared this distance with the length of the drawbar from the end of the threaded portion up to the shoulder that sits on top of the spindle. I discovered that this part of the drawbar was at least 0.3” too short- there was no way for the drawbar to even reach the threads of the collet.
I am not sure if the fundamental problem is the wrong drawbar, or something in the assembly of the machine, bad collets/arbor, user error, or what, but I decided to take matters into my own hands. I chucked the drawbar in a 5C collet in my lathe (G0602) with the shoulder part extending a short distance from the chuck and faced (from the left) the surface of the shoulder that sits on top of the spindle in order to remove material so that the drawbar end would hang lower in the spindle. I carefully removed a bit at a time, testing in the mill after each bit was removed, until the drawbar hung low enough to engage the threads in the collets and arbor. After doing this, the drawbar drew the collets or arbor up into the spindle just at it should. After making this mod, when the retainer cup was screwed back on the top of the spindle, the drawbar did not extend far enough up through the hole in the cup to grip securely with a wrench. Therefore, I also reduced the length of this cup by facing the open end in the lathe by the same amount as the amount of material I had removed from the drawbar shoulder.
I am very curious to see if others encounter this issue or if it something really stupid that I missed. In any case, I am happy with the results and everything now works great and I have made some initial cuts with the with good results. Also, prior to making this mod, I carefully measured and documented the initial dimensions of the drawbar and I could make a new one if I need to in the future.
