586,670 active members*
3,365 visitors online*
Page 18 of 21 81617181920
Results 341 to 360 of 417
  1. #341
    Re: Mach 3 tool setter Big-tex version
    Are you checking for G91 mode?
    Noise shouldn't drive the tool into the table. Noise will make Mach3 think the tool touched the plate before it actually does, and the macro will finish before it even gets to the plate.
    G91 can cause the tool to be driven into the table.
  2. #342
    Feb 2012
    90
    I am now Actually... I don't check for G91 I just force it to G90 each time it runs and then rely on each new routine to set the proper mode which has been working fine. Post #311 has what I did to fix it.... and it drove me crazy until I figured it out since it worked right most of the time.
  3. #343
    I was asking Big Tex.
  4. #344
    Jul 2009
    272
    To be hones t I don't remember this minute got to look it up
    Thank you for your support in developing better cnc experiance.
    Scan my avatar with smart pnone ...... http://www.big-tex.tk/
  5. #345
    Aug 2010
    27
    I got Big Tex's new script and have a problem with it. I followed the instructions in the video. I the initial setup button works as shown.The zero tool setup button seems to be caught in almost a loop. It never would go back to the work piece, but ends up tripping my limit switch in zed. Any idea why this might be happening?
  6. #346
    Jun 2004
    6618
    Re: newbie question on step by step cutting setup/ process in Mach3
    What you should setup is called Safe Z. It is under General Config. No script needed.
    Lee
  7. #347
    Aug 2010
    27
    LeeWay, Thanks for the reply.
    I did change the Safe Z with no change. Maybe the setting are not what they should be. I'm on machine coordinates.
    I can change the tool and have it register it's “Z” hight. It then goes back to the tool change position. If I press Cycle Start the software Mach3 closes. If I press Tool setup button it starts the cycle all over again, but looses it location in “Z” I believe, because it trips the “Z” limit switch. I have my soft limits setup.
    Any idea?
  8. #348
    What version of Mach3 are you using? If you're using 3.43.022, there's a bug in it that can cause mach3 to lock up during tool changes.
  9. #349
    Aug 2010
    27
    Well Ger 21 you're right, that's the version I'm running. So I need to find an older version? If so can you direct me, I would appreciate it.
  10. #350
    No, you can use a newer version. Try 3.43.057 or 3.43.062 from the FTP site, in the Mach folder.
    ftp://anonymous:[email protected]/
  11. #351
    Aug 2010
    27
    Thank you, I'll try them this evening.
  12. #352
    Aug 2010
    27
    Thanks Ger 21 problem solved.
  13. #353
    Apr 2009
    I have just installed the Big-Tex blue probe screen and I use a Metric machine that has X = 1100mm Y=650mm Z=150mm with a feed rate of 5000 for X & Y and 3000 for Z. The auto tool change works well except for the DRO displays down at the bottom. With +1050.0000 entered the DRO display cuts off part of the numbers (it displays 50.0000) as though the figure is too big for the DRO display. The positions entered are correct and the machine goes to where it is supposed to. For an imperial machine you would not use as large a number as a metric machine so maybe the DRO window is too small.
    The other problem I have is that the -x +x -y +y and centre don't appear to work properly. When started the probe feed rate is very slow (around 3.6 units/min) but the touch off does work. I suspect that these macros are in imperial and not metric.
    Any ideas on how to overcom thes little problems?
    Bruce
  14. #354
    thanks
  15. #355
    Feb 2011
    54
    Hello guyz,
    I also have found aproblem in script using mach blue.
    I have modified the speed by which probe moves, but when changing the distance to move out, 3 is the valude deifned, and it states 3 inches in each direction.
    Well, on metric system, its 3 mm, and if there is a gap between probe and edge of the hole is over 3 mm, the probe retracts and measurement is faulty.
    I have changed script and then proble stalls on left wall, not moving back to other side of the hole.
    Any help there?
    Marko
  16. #356
    Apr 2009
    Marko,
    I ended up going for the 2010 Screen Set. It does take some getting used to but it is great.
    It is not as cluttered and everything works once it is all set up and the instructions are very good.
    Bruce
    Quote Originally Posted by lopata View Post
    Hello guyz,
    Any help there?
    Marko
  17. #357
    Jul 2012
    19
    Quote Originally Posted by Big-tex View Post
    new videos are uploaded to youtube and new version 3.4 is officially released
    Thank you all
    Where can I find version 3.4?
  18. #358
    Sep 2009
    1856
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  19. #359
    Jan 2014
    20
    Is the big-tex website down? The link is not working for me?
  20. #360
    Sep 2009
    1856
    have a look in the m3 web site screen sets
    [SIGPIC][/SIGPIC]
  1. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  2. Tool Length Offset Tool Setter
    By CNCneeds in forum News Announcements
    Last Post: 01-03-2014, 06:27 PM
  3. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  4. Okuma Tool Setter Reference Tool
    By lisaclisac in forum Okuma
    Last Post: 09-28-2012, 03:21 PM
  5. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
