Originally Posted by
jimcolt
Electrical noise is tough to deal with.....the most proven method is with very simple grounding circuits with an eart ground rod.....although there are few, if any people that have a good understanding of why this works!
Jim Colt Hypertherm
You may want to check for the implications of a ground rod set up in U.K.
The practice used to be that a ground conductor was never supplied by the service provider and the service was grounded at the supply transformer only, which can be some distance away from the end user, and a Earth leakage trip at the panel was used.
This could mean that the E.L.T. ground conductor could be bypassed in a fault condition.
This is different to the system used in N.A. where the service supplier provides a system ground and it is grounded at the service entry.
Al.
Albert E.
