586,108 active members*
3,185 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > acramatic 2100 hard disk copy
    Feb 2010
    Unhappy acramatic 2100 hard disk copy
    Hi,I have an acramatic 2100 control.its hard disk was damaged.,I copied the hard disk from a similar machine by NORTON GHOST,but it has some alarms.
    when i change menus an alarm occurs on monitor.(your system upgraded ... or some thing like this).
    i think i shulde change some thing in my control or enter machine parameters from damaged hard disk into copied disk or....? i do not know!
    please help me.thank you.
    Feb 2010
    acramatic 2100
    Feb 2010
    Mar 2011
    463
    It sounds like your two machines are running different versions of the 2100 software. Most machines with 2100 controls are running either release 2 (i.e. 2.24, 2.32, 2.34) or release 3 (i.e. 3.22, 3.24, 3.26) software.
    I'm assuming you cloned a hard drive from a newer machine with release 3 software and are trying to run it in a control which is only authorized for release 2.
    If you have other machines with the same software version as the failed hard drive (release 2), clone one of these instead, and you should not have a problem.
    Otherwise, the only way I know of that you could run release 3 software on an older control without getting these error messages would be to contact Siemens and purchase the release 3 option.
    Oct 2008
    123
    have you installed the option code number?
  1. Screwed my Acramatic 2100 Hard Disk. HELP!!!!!!!
    By valiantomer in forum DNC Problems and Solutions
    Last Post: 04-19-2011, 12:08 PM
  2. Hard Disk stepper
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-03-2004, 05:50 PM
