586,281 active members*
3,707 visitors online*
    Jun 2007
    7
    Vacuum or Blower
    We have a 40hp Kaeser vacuum pump at the moment running 1-5x12 table and 1-5x10. When we got both machines running one will error out. So I talked to a salesmen about switching to a blower instead of a vacuum. Just wondering if anyone else has any experience with blowers. Were looking at a Kaeser Blower too.
    JD
    Jul 2006
    1256
    Going from a vacuum pump to a blower is a step backwards.A Kaeser 40HP can pull 29"Hg
    at 535 ACFM which is about 15psi negative pressure.The best their blowers can do is 15Hg which is about 7psi negative pressure.Ask about adding a vacuum storage tank or reducing your feed rate and saving 20 or 30 grand.Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Jun 2007
    7
    Thank you! I see your point.
  1. blower for plasma/torch cfm??
    By DanOSB in forum Waterjet General Topics
    Last Post: 01-10-2006, 02:55 PM
  2. material removal / air blower help
    By DrStein99 in forum DIY CNC Router Table Machines
    Last Post: 10-21-2005, 01:49 PM
  3. Vacuum pump/blower conversion needed
    By Al_The_Man in forum DIY CNC Router Table Machines
    Last Post: 01-17-2005, 03:46 AM
