Hi all,
I have Fanuc 6T-A controller when I try to load a program into my fanuc memory I do the following :
1-set the lock key to write(unprotected memory)
2-set the mode selector key to EDIT
3-Press the READ key
4-set the lock key to LOCK.
This is what I do to cnc, but this does nothing, I read before that when the CNC is ready to receive the information of the program, the initial LSK cominezan to flicker but this kind are not to be done.
I do all the setting required like:
Parameter
000 bit 5 = 1
026 bit 7 = 0 (the bit on the far left) should be a "0" so the control will send Xon/Xoff signals
002 bit 5 = 1
024 bit 0 = 1 (for 2 stop bits)
025 :1 1 1 0 1 1 1 1 (4800 )
under SETTING : Punch code = ISO, INPUT DEVICE 2 = 1
