586,075 active members*
4,034 visitors online*
Results 1 to 11 of 11
    Dec 2009
    54
    11m issue on a Kuraki VMC
    Hi, I have a VMC that has been sitting idle for a while. I've also been away from running machines for about 10 years, so I'm having to re-learn everything.
    The issue I'm having is an alarm that I'm unable to clear when I power up the machine:
    "EX013: Magazine counter missing".
    I've gone through the related parameter here which my Kuraki book says to set the zero bit of parameter K16 to 0. I've done this, and attempted to reset the alarm, but the alarm persists.
    I've check the proximity switches on the magazine (there are two of them) and they seem to be working (at least their indicators light when near metal).
    Any suggestions on where to look? I was thinking that maybe there's a loose connection or some corrosion somewhere, or a bad relay. As I stated above, this machine has been sitting for a while without being run.
    Thanks for any input you can give.
    Feb 2008
    15
    Have you tried to manually jog the magazine around? I had this issue recently and after jogging the mag the fault went away. You should also take a look at the counter table to make sure the data for the magazine size and current position are correct.
    Dec 2009
    54
    I can't manually jog the magazine until the alarm is cleared.
    I'll check data to make sure that the current position, etc is correct.
    The way I understand it, the machine "remembers" or keeps track of where it is in the magazine rotation and has two proximity switches which let it detect the direction and number of pots the magazine has moved the same way a rotary encoder does. Is this correct?
    The machine is being moved today and Friday, so I'm trying to get as much info on this issue as possible before the weekend. I'd like to spend Saturday making the electrical connections and Sunday try to sort out the problem.
    Thanks.
    Feb 2008
    15
    What is the model and serial number of the machine? I will look up some prints.
    Dec 2009
    54
    I have a Kuraki KV-700 3 axis VMC.
    Serial # 8457
    NC Rom # 2020G
    From the Parameters Table:
    Machine # 8457
    NC # A-58343 7184010
    March 9, 1986
    From the Fanuc Data sheet:
    Fanuc System 11MA controller:
    model # A02B-0076-B202
    Serial # 7184010
    Contract # A 58343 -000
    mfg date: July, 1986
    I have the complete set of original documentation for the machine including the Programming manual, User Manual, PC Interface Manual, Ladder, Parts List, the Parameter Table, and the Data Sheets for the Fanuc system.
    Any help you can provide is greatly appreciated.
    Feb 2008
    15
    check your messages
    Jul 2007
    55
    Quote Originally Posted by cwtoyota View Post
    Serial # 8457
    NC Rom # 2020G
    Machine # 8457
    March 9, 1986
    Serial # 7184010
    Do you mind to send me a copy of the parameter table and the date sheet for the fanuc system?
    I lost all the parameter coz the machine didn't power up for too long.
    Don
    [email protected]
    Sep 2006
    Dear Donatello Tam,
    Can you send me the copy of the same .My email id [email protected] .Actually our machine model is kuraki kv 500
    Sep 2006
    can you send me manuals
    Oct 2013
    25
    Re: 11m issue on a Kuraki VMC
    I have a Kuraki machine KV-700 with a 6M Fanuc Controller and do not have any diagrams at all. Does anybody can share diagrams and manuals?
    Machine right now have a problem and can not be ready for working. Need to check electric wiring.
    Oct 2006
    100
    Hello do you still have manuals on this machine ? I need the electrical manual. Control Fanuc 11M
    [email protected]
  1. Kuraki KV500
    By dwamsley in forum Machinery Manuals / Brochures
    Last Post: 11-19-2015, 12:47 AM
  2. Fanuc 16i - Kuraki KBT-13E-A
    By Neziah in forum Fanuc
    Last Post: 05-05-2011, 06:41 PM
  3. Kuraki KV-500
    By SGARCIAM in forum Fanuc
    Last Post: 03-04-2010, 10:36 PM
  4. kuraki KBT 1105
    By caddyshack in forum Uncategorised MetalWorking Machines
    Last Post: 06-24-2009, 03:00 AM
  5. Manuals for Kuraki MH-400.
    By GPena in forum Fanuc
    Last Post: 02-27-2009, 09:51 PM
