I thought my recent problem with SprutCAM 7 had been resolved. Switching off the Turbo 3D simulation mode (which is enabled by default) fixed a glitch in the simulation display, but a serious underlying problem is still present.
Files which can be imported as parts with no problem will not import as workpieces. They show up if Geometry Model Visibility is enabled, but they cannot be made visible as workpieces.
Machining operations which run without errors (green checks across the board) will not simulate. The tool appears and moves in the simulation screen, but no geometry appears and the Simulation Result is empty. The geometry can only be made visible by enabling Geometry Model Visibility. Nothing can be made to appear as Workpiece or Simulation Result.
Models which Machine and Simulate normally may display the above problems after being saved and re-opened.
I think SprutCAM 7 is broken. Is anyone else seeing similar problems?
