586,655 active members*
4,080 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Controller Retrofit for Calypso and Other Older Waterjets
    Feb 2009
    12
    WARDJet offers a 100% turn-key solution for waterjet companies with older waterjets. WARDJet X-Series Controllers will extend the capabilities of nearly any waterjet system (virtually any controller can be retrofitted).
    ACS Precision, LLC, Mercersburg, PA, retrofitted their Calypso waterjet with a WARDJet X-Series Controller. Charlie Daniels, General Manager of ACS Precision, found that while one company was promising a beta model for a controller, no other company at that time had a controller that could be retrofitted to their Calypso waterjet with the features demanded. Daniels met with Richard Ward, President of WARDJet, a leading manufacturer of waterjet systems and accessories. Ward’s philosophy of open architecture regarding hardware components won them over.
    ACS Precision is extremely pleased with the WARDJet X-Series Controller’s features. The high tech graphics & split touch screen allow the waterjet operator to see every line of code, so any issues can be spotted before a cut is made. The way the controller jumps to any point on the contour even if that part has not been cut, allows total freedom for the operator. With the retrofit, they can run all programs, old and new and all the files they’ve received from customers.
    ACS Precision waterjet operators are also finding the WARDJet wireless PDA pendant, carried or worn on the belt, to be tremendously useful, allowing them to move away from the machine. The pendant untethers the operator from the waterjet and allows them to turn their attention to other machinery on the floor. Daniels thought that this would prove even more practical in a smaller job shop. When ACS Precision operators needed guidance they took advantage of the live interactive WebEx support with WARDJet technicians.
    WARDJet’s goal is to incorporate the latest, state-of-the-art technology for their WARDJet X-Series Controller so that almost any company can extend the capabilities of their waterjet system, even if it’s not a Calypso.
    WARDJet is a leading designer and manufacturer of new and custom waterjet systems for precision cutting and machining applications. Their open-architecture CNC platforms are designed to accommodate multiple machining processes such as drilling, tapping, reaming, rotational indexing or multiple-head 5 axis waterjet cutting. WARDJet systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. WARDJet waterjet systems are made in the U.S.A. For more information contact the Sales Department, ph: 330-677-9100, ext. 6; fax: 330-677-9121; www.wardjet.com, [email protected].
    WARDJet Waterjet Cutting Machines
    http://www.wardjet.com
    Aug 2011
    23
    How much? Does it have ramping built in?
  1. Calypso control software
    By cagedxj in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-18-2017, 09:48 PM
  2. Convert/Retrofit old Precix HPGL controller to G-code
    By Blluitt in forum Commercial CNC Wood Routers
    Last Post: 01-14-2012, 05:42 AM
  3. Flow vs. Calypso Waterjets
    By AplusWizard in forum Waterjet General Topics
    Last Post: 05-02-2008, 04:16 PM
  4. Help Older CNC JR controller pinout for Mach III
    By sandtoysrus in forum Servo Motors / Drives
    Last Post: 03-17-2005, 08:14 PM
