586,655 active members*
3,001 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 400 with 21iTB control
    Jul 2005
    42
    Does anyone know how to turn on ez guide on this control.
    Apr 2010
    MGi - enabled
    If the control is ready with MGi files (you should see Manual Guide loading ..... screen when control is booting) then you can check MP14700#7 = 0
    Swatt
    or hit the custom button on the fanuc screen...
    this also shows a option EZ-I (easy guide)
    this happens when tool load monitoring is installed
    if you see the EZ-I under the custom button press it, still no manual guide switch to edit or memory mode and press prog (some times hit prog twice)
    Jun 2010
    Has anyone had problems with the waylube system in the 400LM. Keep getting waylube alarm, tank is full, no leaks. I am baffled.
    Oct 2009
    30
    Easy fix
    Quote Originally Posted by cncturnmaestro View Post
    Contact your local dealer and order a new float switch. Occationally u get a bad 1. Pop the top and you will see 2 or three wires attached to the top of the long tube that enters the waylube tank , remove wires with power off and replace the "float switch"
    good luck
    von007
  1. PUMA 240 M
    By turnn in forum Daewoo/Doosan
    Last Post: 12-09-2009, 06:36 PM
  2. Fanuc 21itb Not showed MAcro list
    By Selimsalim in forum Parametric Programing
    Last Post: 08-28-2008, 09:11 AM
  3. Daewoo puma 12-l fanuc 0-T-A control
    By smts in forum Daewoo/Doosan
    Last Post: 03-29-2008, 02:27 AM
  4. Differences between Fanuc 0ITB and 21ITB
    By malonet in forum Fanuc
    Last Post: 02-13-2008, 08:30 PM
  5. SV023 Alarm on control boot up - Puma 6 with 10T
    By Radius in forum Daewoo/Doosan
    Last Post: 08-31-2007, 04:39 AM
