Mach2 G02, G03 Modal?
I have just started to familiarize myself with mach2.
I loaded a simple lathe program and tried to cycle thru it. In the display there are lots of lines, why? and when the program runs all moves after a g02, g03 are circular ?? only feed moves are supposed to be circular, not the rapids! what gives is there a switch I am missing?
sorry I was incrementing the program too fast.
what the real problem is. is the IJK comands aren't machinging correctly. I change the IJK in the config from incremental to absolut and back and it makes a change but it is still wrong. I use the HAAS post for a standard fanuc style g code.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
