Hello,
I am having a problem with our 1999 Fadal 4020. Things are running along smoothly, then for no apparent reason, at the start of a new cycle, it starts dwelling at each x and y rapid position.... it will stop for 2-3 seconds at each position before moving to the next position. I thought maybe it was in a G9 mode and thru MDI, I input the G8 and tried again - no change. I have tried different programs - programs are generated thru Mastercam - no change. It does it when you input several x y moves thru MDI as well - but only on the rapids - does not do it once it is in a G1 move. This has happened several times over the years. In the past, I have shut down the machine, re-booted, and all was good again. Does anyone have any suggestions?
Thanks in advance!
