586,033 active members*
3,368 visitors online*
    Feb 2010
    3447
    Question Ball screws & linear rails.
    http://cnczone.com/forums/showthread.php?t=100925
    This is my build in progress.
    I would like to find a store that sells ball screws as well as linear rails. Please shoot me some popular suggestion with good deals.
    I need pillow blocks (end supports? correct me if i'm wrong) for all the ball screws as well. I have no clue what the difference between a simple pillow block and a fixed block is, and when it comes to the machined ends i'm lost. I do know that i need a ballnut flange that is square so i can bolt it to my gantry.
    Some one enlighten me.
    Thanks.
    Feb 2010
    3447
    http://www.cnczone.com/forums/showth...?t=8813&page=8
    I read the entire article on ball screws and now i basically get a decent understanding of whats going on with the fixed end, simple end etc. Thank goodness. Now where should i go to buy all this stuff?
    Feb 2010
    3447
    http://www.kelinginc.net/SlideBlock.html
    Are those ball screws and end supports they sell any good? The price is awesome. Couple those with some Hiwin linear rails and blocks from:
    http://www.automation4less.com/linear.htm (Heavy duty series)
    and i would assume i would have a fairly decent motion setup...
    As far as the "end machining" on the ball screw i want to attach a gear to it so i can couple it with the other ball screw, so i will have a dual ball screw setup pushing the gantry to help eliminate binding. Do they sell them already machined with a single sided flat surface and keyway or...?
    thanks for your help.
    Mar 2004
    439
    You should check out Misumi:
    http://www.misumiusa.com/
    Just about everything for automation & then some.
    Keith
    Jul 2006
    1256
    From China.Many zone guys have purchased and have no complaints.I have only heard good feedback.
    http://stores.ebay.com/linearmotionbearings
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
  1. In progress - 8020, linear rails, ball screws, steppers
    By stevespo in forum CNC Wood Router Project Log
    Last Post: 07-25-2012, 05:10 PM
  2. Ball screws and linear rail
    By mike2768 in forum DIY CNC Router Table Machines
    Last Post: 06-06-2009, 03:17 PM
  3. The use of screws for linear rails as well
    By CNCDevil in forum Linear and Rotary Motion
    Last Post: 08-18-2007, 11:50 AM
  4. Sources for new BIG ball screws and rails?
    By ewest in forum Linear and Rotary Motion
    Last Post: 05-21-2007, 04:56 PM
  5. Acme screws as linear rails?
    By bb99 in forum DIY CNC Router Table Machines
    Last Post: 12-26-2003, 10:24 PM
