586,055 active members*
4,097 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > 5'x5' Water Jet Cutting Machine Ideal for Small Shops
Results 1 to 5 of 5
    Jetedge Guest
    Arrow 5'x5' Water Jet Cutting Machine Ideal for Small Shops
    Jet Edge’s 5’X5’ Mid Rail Gantry Waterjet System is an ideal water jet cutting solution for shops that cut smaller material or have limited floor space available for machine tools.
    Powered by a 60,000 psi or 90,000 psi Jet Edge waterjet intensifier pump (available in 30-200hp models), the 5’X5’ water jet cutting machine features an exposed 72”X72” tank that easily accommodates overhead loading. It is designed to cut virtually any material up to 60”X60”. If equipped with an optional second cutting head, it can cut two parts up to 30”X60”. Optional mirroring cuts part cycle time in half.
    The Jet Edge Mid Rail Gantry water jet system utilizes an industrial PC controller and can be configured so that all three axes are fully programmable (Z optional). It also features direct-couple AC brushless digital servo motors and single or double carriages. Critical bearing components are protected with heavy metal covers with brush seals. The Mid Rail Gantry waterjet system also is available in 8’x5’, and 21’x5’, 8’X13’ and 21’X13’ and 5’x13’ work envelopes.
    Jet Edge’s Mid Rail Gantry Waterjet System is proudly made in the U.S.A. For more information, visit www.jetedge.com, e-mail [email protected], call 1-800-JET_EDGE (538-3343) or 763-497-8700.
    About Jet Edge
    Established in 1984, Jet Edge is a global designer and manufacturer of waterjet systems for precision cutting, surface preparation and coating removal. Jet Edge systems are used around the world in a broad range of industries, from the world's leading airlines to automotive, aerospace, industrial manufacturers, machine and job shops. Jet Edge waterjet systems are proudly made in the U.S.A.
    More Information
    For more information about Jet Edge, visit www.jetedge.com, e-mail [email protected] or call 1-800-JET-EDGE
    (538-3343).
    Information Request Form
    Sep 2010
    portable cutting machine water jet 236340
    Portable water-jet cutting JET EDGE
    Max. 55 000 psi (3800 bar) | Versacutter
    See the translation
    The Jet Edge Hydraulic Versacutter is a motion-controlled, portable abrasivejet cutting and beveling system. The system is used in a variety of water jet cutting applications Including pipelines, steel reinforced concrete reactor vessels and fabricated metal structures. The Versacutter cuts without flames and does not generate heat. This Makes it possible for operators to cut in Areas WHERE flames are restricted, and eliminates heat-affected zones.
    The Versacutter is powered by Jet Edge Ultra-High Pressure (UHP) Water Jet Intensifier Pump That supplies 55.000 psi (3.800 bar) water to the cutting devices as it travels along the track. The cutting device can be configured on a flexible track for contured cutting surface or on a frame-mounted, rigid track for linear cutting.
    A remote control panel designates the direction of the cut, starts and stops the drive motor, adjusts the travel speed, and monitors delivery of the abrasive. The drive motor is a sealed unit Which Operates on reversible hydraulic power to propel the sprocket through the gear reducer. The sprocket FOLLOWS the track and the cutting head moves along the selected path. The tracks are Easily Positioned using earth permanent magnets, vacuum, and / or cable tensioner. The self-propelled carriage cutting and beveling FOLLOWS accurately track the assembly using positive engagement drive pins.
    The pneumatic delivery system meters the abrasive from the hopper to the cutting head. The controlled slidegate micrometer measuring device features a large readout calibrated dial and a positive lock setting for accurate and repeatable delivery abrasive.
    Sep 2010
    I sell waterjet cutting machine with high quality and competitive price from China.
    The CNC five-axis dynamic water jet cutting machine is our newest product.
    If you're looking for it please feel free to contact me directly at [email protected] , I will send more details to you.
    Sep 2009
    313
    Why is there a thailander talking about your product like he made it? I'm interested in your 5'x5' 90,000psi system. I checked out your website and don't see a stainless steel frame, that's discouraging "unless your price is much lower". PM a price for the machine I specified, I'd really appreciate it.
    Jun 2011
    a water jet cutting video of China waterjet cutter
    [ame=http://www.youtube.com/watch?v=DV6YJzXuREE]China waterjet machine, China waterjet cutter, China water jet cutting machine - YouTube[/ame]
  1. CNC Cutting Machine Water Bed
    By sgsrao21 in forum Waterjet General Topics
    Last Post: 04-24-2009, 08:56 PM
  2. Small/Garage shops and the old Bridgeport.
    By katiebo in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2008, 02:56 PM
  3. Video of water cutting machine
    By ynneb in forum Waterjet General Topics
    Last Post: 03-04-2006, 01:32 AM
  4. eMachineShop will kill small shops?
    By SimonArthur in forum Community Club House
    Last Post: 09-15-2005, 04:41 PM
  5. Replies: 2
    Last Post: 04-30-2005, 11:34 AM
