Hi guys - I have been wondering how us DIY'ers might go about building an accurate machine with reasonably long travels (say 2000mm/6 feet) using off the shelf linear rails etc.
It would seem that one of the biggest problems is making the rail mounting surfaces accurate along such a length without access to an even bigger machine to simply grind or mill the surfaces flat. I was wondering if anyone had sucessfully tried turning the problem on the head, and used the linear rails as the accurate surface to which to align a machine base.
Feel free to shoot me down, but, the rails are straight during manufacture, and so presumably straight when unstressed and resting on a flat surface like a mill's table or a large suface plate. If you could machine some accurately flat short cross pieces, couldn't you then mount them to the back of a pair of rails, and create a rail + sleeper affair, with the rails parallel and at the same height.
If the 'sleepers' had horizontal slots in them, you could then through bolt them to the verticalish side of some angle iron which you'd milled vertical slots into. The horizontal side of the angle iron would have slots or holes to allow it to be bolted down to some solid chunks of imprecisie iron that would run along the length of the rails. If you then adjusted and tightened all the bolts to get the imprecise bits as solid and square as possible, wouldn't you still have a set of precisely aligned rails, now bolted onto a pretty imprecisie but solid base? If you then added a dozen or so adjustable feet to the I-beams, wouldn't you end up with a large floor-standing machine base with precisely aligned linear rails?
Here's a quick CAD mock-up of what I'm on about:
