586,409 active members*
3,019 visitors online*
Results 1 to 16 of 16
    Apr 2005
    Fanuc graphic
    I have a Fanuc Oi m control and I read in my manuals about tool path graphic and conversational programing.Is any of this available to me or are the special options.
    24223
    IIRC The FAPT conversational language that Fanuc developed for graphical programming, on older Fanuc's had to have a board installed, but I am not sure on the Oi, most of the options are in the control on Fanuc, they just need turning on. Fanuc should be able to tell you what way you have to go, But usually there is a different keyboard also, with a FAPT selection key on it
    Al
    Albert E.
    Apr 2013
    17
    Re: Fanuc graphic
    Have you a button marked "custom graph" ?
    Feb 2006
    1792
    Re: Fanuc graphic
    They call it Dynamic Graphic Display which is an option.
    Set proper machining conditions. Go to AUTO mode. Then,
    CSTM/GR mdi key > GRAPH soft key > OPRT soft key > EXEC soft key
    If you see all the soft keys, the option is available. It would trace toolpath without tool movement.
    If it is not available, you may run the graphics in Program Test Mode. But, after this, you would need to cycle power for actual machining.
    Apr 2013
    17
    Re: Fanuc graphic
    Quote Originally Posted by sinha_nsit View Post
    All Tornado 220M's have graph facility the button would be "custon graph" not "cstm gr" that will be on the 220 ie 2 axis only machine
    Feb 2006
    1792
    Re: Fanuc graphic
    The sequence of operation might be similar.
    Aug 2011
    2517
    Re: Fanuc graphic
    the graphic function could be there but it's not for programming. it merely traces the path. its pretty useless.
    full conversational graphic functions in Fanuc controls requires hardware. you cant turn it on if its not there.
    Apr 2013
    17
    Re: Fanuc graphic
    There is no confusion.... the 220M definitely has graphical view, ie tool tip tracing that you can see as the tool moves. and the 220M can also have "manual guide" however this is very rare on a 220M and would require more than just a Fanuc unlock...
    The graphical view is very handy when you are programming in type 2 lets say something simple like the thread section of a bolt complete with undercut, the problem is that the undercut is done in one hit and if excessive the graphical view allows you to watch it as it digs in...
    So the cutter starting at X=0, Z=0 moves in X to the start of chamfer then along the chamfer, along the "threaded" section then "digs" in to create the undercut and then off up the head.... very handy, if the depth of the undercut is too great you can see it going in and if necessary stop it. more modern machines will allow you to step the undercut.. in my experience most people have no idea of the powers of type 2 programming in respect of double angles and counter bores, and my favourite spheres on the end of a shaft watching the complete ball being turned in one hit :-)
    I can tell you exactly what you need to do but I was hoping the OP was going to come back on here ... I have noticed they are active and even looked at this thread but then left ?
    Feb 2006
    1792
    Re: Fanuc graphic
    Dynamic graphic display traces toolpath without physical tool movement. I often use it for proving a new program. Unexpected toolpath indicates an error in program. Since there is no tool movement, one may execute the program without any apprehension of crash.
    Apr 2013
    17
    Re: Fanuc graphic
    It does, but if you step through each line it can be easier and quicker, I haven't had a crash in years doing it my way, if I used CAM then I would definitely use the "DRY RUN" button
    Feb 2006
    1792
    Re: Fanuc graphic
    Dynamic graphic is quicker than dry run. It traces the toolpath in no time. Step-by-step execution is also possible, for a closer observation, if desired.
    If there is some serious problem in the program, dry run may not be safe.
    Apr 2013
    17
    Re: Fanuc graphic
    What do you mean by dynamic graphic ?
    All that a 220M has is the graph feature and DRY RUN and on a few "MANUAL GUIDE" nothing else...
    Feb 2006
    1792
    Re: Fanuc graphic
    Dynamic graphic traces tool path WITHOUT physical tool movement. Refer to Fanuc's Operator's Manual for more detail.
    It is independent of manual guide.
    Apr 2013
    17
    Re: Fanuc graphic
    It is also independent of the Tornado220M !!! ie it is NOT fitted or able to be fitted to my knowledge.
    Feb 2006
    1792
    Re: Fanuc graphic
    It is available on Fanuc controls i-series. Not sure if available on earlier controls also.
    Apr 2013
    17
    Re: Fanuc graphic
    not on a 220M 3 axis mill turn
  1. Replies: 8
    Last Post: 01-08-2023, 07:04 AM
  2. x4 graphic issure
    By steven97 in forum Mastercam
    Last Post: 11-11-2010, 11:18 AM
  3. Graphic Wraps for your cnc
    By KustomKoncepts in forum Camaster
    Last Post: 11-23-2008, 12:10 PM
  4. Graphic Work
    By lal19541 in forum Uncategorised CAD Discussion
    Last Post: 04-05-2007, 08:30 PM
  5. G Code to Graphic
    By AJFab in forum G-Code Programing
    Last Post: 06-02-2006, 01:20 AM
