586,634 active members*
3,069 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Work/toolpath offset-Question..
    Jan 2007
    260
    Hi All,
    I hope that what I am about to ask is not totally stupid, but here is what I am trying to do:
    I have a part, which I want to cut say 8 times. This part will be made out of the same sheet of material (1/8 aluminum). Now, it is simply a 2D cut, and I have also created a .dwg file, that basically has the parts laid out on the sheet, of 12x24 material (eight in total).
    What I want to do, is to create a profile cut, to say cut the first part, then translate the SAME tool path to a point on the second part (as an origin) to cut that part, then on to the third etc.....
    In other words, I want to keep cutting the same countours, but only after I re-position (translate) for the other origin position of the piece, with out having to re-create or choose the geometry over again (since it is the same tool-path, just in a different spot).
    Any easy way to achieve this with WCS and off set numbers in Mastercam X3?
    Have tried all sorts of combinations, but I keep failing at doing this...and I am sure I am overlooking something simple....
    thank you in advance for any suggestions....
    http://www.cncguitar.com
    Jun 2005
    305
    The easiest way to do this is with the transform function.
    You do not need to declare new work offsets (unless you really want to).
    Attached is a VERY simple example of 8 profiles in one sheet in MC9 format.
    P.S. NEVER be afraid to ask a "stupid question" here.
    Every person here has asked the same question (and others) before.
    This is what we are here for, to help others with the problems we have already solved in the past
    Attached Files Attached Files
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Jan 2007
    260
    Thanks!
    That makes PERFECT sense, and works like a charm!
    I knew it was something obvious I was overlooking....that translate tool path is AWESOME! and a real time saver...
    Thanks for taking the time to illustrate it so well! Much Appreciated!
    Jun 2005
    305
    You are quite welcome.
    Always glad to help.
  1. work offset
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 11-23-2009, 12:41 AM
  2. 6M-B 4th & 5th axis work offset changes
    By R-Bob in forum Fanuc
    Last Post: 10-08-2008, 06:33 PM
  3. Daewoo EZ-Guide Work Offset Question.
    By kjetton in forum Daewoo/Doosan
    Last Post: 05-29-2008, 12:53 AM
  4. Work Offset Question
    By Cartierusm in forum Mach Software (ArtSoft software)
    Last Post: 11-29-2007, 10:50 PM
  5. work offset in fanuc 6m b- help
    By rags in forum Fanuc
    Last Post: 08-04-2006, 03:39 AM
