Hey every one, this is probably a redundant thread and I'm sorry but I tried to search for answers to my problem with no avail. I just finished building my first CNC router using Ebay (I know I know!) ballscrews. Its just for playing around in the garage so I figured these would be fine.
Well after getting everything set up and the machine cutting out parts I noticed they are all coming out undersized. When I tell it to cut out a 2" circle, the circle actually comes out to be 1.915 in diameter. The ballscrews I bought are metric (16mm in diameter) From Ebay seller "Linearmotionbearings2008" Who sells TONS of these ballscrews there. I was skeptical when I was told they have a thread pitch of 5 turns per inch because if they are metric in diameter I would assume the pitch is metric as well. after cutting a few parts out I can say for sure they are NOT 5tpi...
Is there a way to calculate the tpi on these ballscrews now that the machine is up and running? Or does any one know the real TPI on these ballscrews? Thanks for any help! I have attached a picture of my homemade CNC router I built that is cutting the undersized parts.
-Jerome
