Originally Posted by
RotarySMP
I know how frustrating trouble shooting CNC flakiness can be. The mechanical stuff is easy to get your head around, but if it is issues like pulse train stablity or noise interference, you need to be very patient and systematic.
Have you tried running a program for a couple of hours continuously to see if you are missing steps? your want an assymetical program like rapids of an inch at a time in one direction, then a slower feedrate move back to start.
"when I move the ballscrew clockwise and then counterclockwise, the dial indicator will show about .001 to .0015 movement in the same direction before the carriage starts moving the other direction. It happens both ways."
This sounds like your ball nut has play. Mine does too. Not a big deal on a lathe on Z since almost all cutting is in one direction. A second nut in an anti backlash config would help, but on Z this is hardly worth worrying about.
Have you tried installing TurboCNC, or EMC2 and see if you have the same issues. Or run a different computor? TurboCNC and the essential bits of Dos can be loaded on a couple of floppies, so you don't even have to install it.
