586,080 active members*
3,771 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > I burnt one of the axis. Can I still use the other three?
Results 1 to 8 of 8
    Mar 2010
    While testing one of the axis I got the "pop" and "burnt" smell. I assume there is no chance that driver might still work.
    The board seems to be shorted at the moment, but it still has three other drivers.
    If I cut the pins on the burnt driver and remove it should the rest of the board function?
    I don't know much about electronics so bear with me.
    Fernando
    Dec 2005
    258
    You shouldnt have to remove the IC, but yes you can use the others.
    If you would like to have it repaired let me know.
    Eric
    Mar 2010
    Quote Originally Posted by dbtoutfit View Post
    Eric
    Hi dbtoutfit,
    Thanks for the reply. You mention that it shouldn't be necessary to remove the IC, but the board does seem to be shorted and causes the power supply to shut off.
    Is there an easier way to remove the short? Should the board work by just removing the IC?
    Fernando
    Dec 2005
    258
    sorry,
    You shouldnt have to.
    I will say I am little concerned you have more than just a pop ic since its knocking your psu off.
    I have had ic go bad on me but never caused the psu not to work.
    The bad ic maybe causing another problem so go ahead and remove it.
    Eric
    Apr 2010
    Burnt axis
    Fernando,
    I recently fried a axis. Noticed that the ic was getting very hot and decided to remove it to see if board would power up. That worked for me.
    Stan
    Apr 2005
    12
    Resurrecting this thread because the Z drive on my 3-axis Xylotex died last night. Pins A and A- are shorted to Vbb and Gnd. I believe just the Z axis IC is shot and shorting pins internally. Does anyone know of someone who will repair these boards, or a source for the IC and schematic? I have the skills to repair it myself but I need to find the parts.
    Would prefer to keep this board since I made the case and cables custom for it. Thanks for any help.
    Jan 2006
    2985
    An earlier post looked like an offer to repair the OPs drive. I'd guess he knows how to do it.
    Matt
    Dec 2005
    258
    Jtheletter,
    Did you repair the board? I have a few New IC's in stock most the time.
    I'd be more than happy to take it off your hands if you no longer use it. lol
    I have had to replace many things on this board. Repairing the Buffer IC is by far the funniest. NOT. However when they go bad you generally don't have to replace it and can just use the other legs as 1 or 2 gates are not used.
    Eric
    Sent from my Samsung S3 on Tapatalk 2
  1. CNC On A Budget - Burnt!
    By Rhodan in forum Community Club House
    Last Post: 01-18-2011, 07:55 AM
  2. How to Maximise Burnt Edges?
    By aaronseymour in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-12-2010, 03:24 PM
  3. trying to get my milling machine working burnt compacitor
    By hmcl281 in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2007, 07:47 PM
  4. Burnt out motor and gecko 201 ???
    By 2fst4u in forum Waterjet General Topics
    Last Post: 05-01-2007, 03:19 PM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
