Can anyone send me photos of your mach3 port and pin settings
I'll post one soon. Have to get it from the machine.
Here is the xml file and screen set, so you don't get a blank screen.
The files are zipped, so your browser does not try to screw with the .XML file.
It also has a cycle start button wired the the 4th axis limit switch input.:withstupi
Rapids are set to 1500 max but will work at 2500 x and y, and 2000 on Z.
Reduced feed because DMA access on PC interrupts process, so slowed to avoid stepper lost pulses.
If it will rapid continuously x-250 to X0 and back with no clunks increase the speed in motor tuning.
Sorry it is metric, but that's what we do here.
Cool, thanks
Look at post #2 for the file and details.
Thanks, that should really help.
