Is there a way to use the mx3 to control the cutter comp? I am currently using the surfcam to offset the cutter (offset with comp) but once on the machine I am unable to make adjustments in the control with cutter comp. I must set the cutter size to .0001 in the control when I load an EIA program. Then if I want to make an adjustment I must then repost the program with a different size cutter.
Any ideas?
