Hello there. I recently found a manual Compact 5 that I'm thinking about buying (it's local) and I'm hoping that some of you can share your experiences and help me make an informed decision. The lathe in question appears to be in very good shape having only been lightly used by a professional machinist and includes the milling head. I've done as much reading as I can (there doesn't seem to be much out there) and have the following concerns:
1. Is the capacity of this lathe really limited to less than a 4" turning diameter? Generally the pieces I'd be working on would be less than this in metal but I'd like to occasionally use the lathe for wood turning and those parts are a bit larger (3"+) and I'd like the lathe to be able to handle this.
2. Is tooling for it standard enough that I won't have issues finding it?
3. Would I be better buying something like the JET JHL-610 for the small work I plan on doing with this? Feel free to make suggestions. My local machine shop has a jet on the floor which is why I mentioned.
4. Thoughts on a fair price? The seller is asking ~$700.
The milling head that comes with the lathe is a bit of a bonus but I plan on getting a proper mill so it's not a big deal if it's limited in what it can do.
Thanks in advance,
Nate
