586,094 active members*
3,906 visitors online*
    Mar 2005
    18
    Linux/EMC file conversion help needed
    I just installed BDI/EMC Debian kernel Linux on my Sherline mill - I can run g-code written with a text editor just fine. But all of the CAD programs on the disc (Sherline) save in a format that EMC will not load (Synergy and QCAD). Is there a good Linux based CAD program that will generate g-code in a format that I can read? Preferably Linux GNU based. Or is there a conversion program for .syn and .dxf files?
    Nov 2003
    51
    check this link:
    http://www.ribbonsoft.com/camexpert.html
    emc does not understand dxf files, the above will convert your dxf to an nc file, upload that to emc.
    jerry
  1. CNC mini-lathe conversion help needed.
    By minilatheman in forum Mini Lathe
    Last Post: 05-24-2005, 01:47 PM
  2. Advise needed for rotary table conversion
    By spoiledbrat in forum DIY CNC Router Table Machines
    Last Post: 05-11-2005, 08:34 PM
  3. Vacuum pump/blower conversion needed
    By Al_The_Man in forum DIY CNC Router Table Machines
    Last Post: 01-17-2005, 03:46 AM
  4. File conversion
    By signIT in forum Uncategorised CAM Discussion
    Last Post: 06-13-2004, 11:55 AM
  5. File conversion
    By JOE65 in forum Autodesk
    Last Post: 05-28-2003, 01:57 PM
