586,117 active members*
3,442 visitors online*
Thread: Memory
    Mar 2010
    21
    Memory
    I have a new Citizen A220 and turned a .5 sphere. I would like to do some simple engraving on the sphere. I wrote a program in Mastercam, edited the posted program to work in the Citizen and made it into a subprogram. The program is somewhat long, not terribly, and I can't get it all to load into the control. Is there any way to run a program with any significate size on this machine?
    Oct 2008
    31
    Check your compos page under parameters for a option known as "program pre analysis check" - or something like that.
    If this is active the machine will precheck the program for syntax errors etc and the program size will be limited by the memory buffer. To turn off press set and deselect, recall your program in prog select mode and try again. When this is not checked the limitation is removed I think. When this option is active the programs run 1 or 2 secs quicker
    good luck
    Mar 2010
    21
    Thanks, I have seen that switch and I'll give it a try. I find it hard to believe this new control would have such a limitatation with it's memory capacity. Thanks for your help.
    Oct 2009
    84
    Memory sizes that come with the machine are options, your control may not have the right option enabling you all the extra memory you want.
    Citizen really doesnt like to give away anything they can potentially charge you for :P
  1. 16M Memory
    By 9566317 in forum Fanuc
    Last Post: 12-02-2008, 02:46 PM
  2. ANYONE KNOW HOW TO ADD MORE MEMORY
    By dbassva in forum Fadal
    Last Post: 05-22-2008, 01:49 PM
  3. need more memory
    By rob2424 in forum DNC Problems and Solutions
    Last Post: 01-28-2008, 12:04 PM
  4. M-2 Memory
    By newguy81 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-05-2007, 07:13 AM
  5. 88 Memory ?
    By Bear in forum Fadal
    Last Post: 09-01-2006, 12:26 PM
