Attached are some pictures of a lighted dust shoe I am making. It is a polycarbonate (cutting board) frame with a 2.5 hose connection for my Shopvac/dust deputy hose. I've also added some high intensity LEDs for illumination of the cutting area, as well as a laser cross hairs projector for zeroing X and Y. I will be adding a "Zero Laser" button on my Mach screen to "zero at the present location, add the x and y offset (from the laser intersection to the true router bit center) to the x and y DROs, then goto to x and y zero."
The laser was $10.00 on ebay, the LEDs were 5.00 for 4, the laser has a 3.3v power supply on the perfboard (I dislike batteries) and I already had a 12v source from the controller to feed it. I also added a $3.00 switch on the perfboard to switch on/off the laser. Probably $4 worth of cutting board, the rest I had (like wire, shrink wrap, jack/plug for the power, perfboard, some dropping resistors, capacitors.) Sorry about the hand wiring, but I haven't climbed up the CNC PC board learning curve yet.
Next, I am going to add a magnetic base plate with brush walls to ride under it, as well as a fixture TBD to help hold the hose at the top of the carriage.
