586,108 active members*
3,293 visitors online*
Thread: cnc spindle
    Feb 2010
    71
    cnc spindle
    hi ppl. i plan to make my own spindle, so if someone knows dimension of the spindle collet holder?
    outside diameter, inner diameter and depth of the holle in which collet goes. please tell me.
    Jul 2007
    887
    Well, that depends on which type and size of collet you're planning to use. I'm sure there are tens of different types of collets and then each type usually comes in different sizes as well. Like ER8, ER11, ER16, ER20 etc.
    Here's a .pdf with dimensions on the ER-collets, if you choose to go that route. I'm sure a little a Google search will bring up similar references for other types of collets.
    Feb 2010
    71
    thanks mate. you relay helped me.
    This is exactly what I was looking for, i will use ER16 cullet,for it i will make a slot in my spindle.
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. spindle motor and spindle control dont work
    By customcncparts in forum Milltronics
    Last Post: 10-01-2009, 08:08 PM
  3. Feed rates / spindle speeds for HF spindle
    By yngndrw in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2009, 04:46 PM
  4. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  5. Lathe spindle bearings and spindle material
    By mackeym in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 04:53 PM
