How to handle the warping.
I made a ring shaped pressure brush that fits over the spindle and the brushes press the PCB down, so warping is no longer an issue.
Actually 2 laser cut exhaust flanges spaced apart by some threaded rods (from clamp set).
Bottom flange has a chopped up broom - five pieces attached to bottom ring.
Very similar to the way a real PCB drilling machine holds down the PCB except that they usually have a live actuated brush that can retract independently.
Using this method, a 0.3mm bit will last all day.
Without it you can't move more than about 10-20mm from the reference point before the board warps upwards, and the fine bit goes too deep and shears off.
Only takes a minute to set this up. Just clamps to the quill.
The PCB only needs to be lined up on a couple of pins. Inline at the right spot is perfect for double sided alignment.
No more tape, clamps, screws or any of that stuff.
I will post a picture when I get time.
