586,108 active members*
3,112 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Leadwell MCV-OP with Fanuc Series OM missing O9001 macro
Results 1 to 18 of 18
    Mar 2010
    Hi
    I work in a vocational school and we have a Leadwell MCV-OP with Fanuc Series OM controller and it has been reset all the way and is missing O9001 tool changer macro.
    I got it talking with pc via rs232 after some work thanks to the internet including this forum so there feels to bee some light in the darkness.
    I got one Fanuc OM O9001 macro but that does nothing.
    Any one out there have pointers to right direction?
    atorox
    Jun 2008
    1511
    Well it is going to depend on a lot of things. Can you call leadwell and see if they have the macro?
    It will depend on how the MTB set up the ladder to do tool changes. Some are done just by having the M6 programmed. Others can have a custom code set up for the M6. If you are using program 9001 for the tool change macro then I am going to ass u me that a custom code was set up to call program 9001. So knowing that you will need to have #240 set to 6. This will call program 9001 every time that M6 is programmed.
    Now you have to make program 9001 and place your code in it to do a tool change. The code below is the most basic to try and get the job done but may need to be tweaked depending on how the ladder does the change.
    O9001(TOOL CHANGE PROGRAM)
    G40G80—(tool dia cancel & canned cycle cancel)
    G91G28Z0M9—(tool change position in Z & coolant off)
    M19--(tool orientation)
    G28Y0M5—(tool change position in Y & spindle stop)
    M6—(tool call of modal T value)
    M99
    Now if this does not work it may be a matter of having to place the T() value being called in the M6 command or it will read the modal T. Lets try this first. If we have to go the other way and change it you will need macroB on your control. Which was probably already set up if the tool change was programmed that way.
    Here is a link to a few other threads that discuss the tool change set up.
    http://www.cnczone.com/forums/showth...highlight=9001
    Stevo
    Mar 2010
    No O9001 macro needed for Leadwell MCV-OP with Fanuc Series OM
    We got the fanuc running now and O9001 macro was not needed even though one source had said that it is needed. Problem was in parameters in the end.
    Jun 2008
    1511
    You are correct it is not always needed. It depends on how the MTB set it up. It is just nice to have all the positioning code done in a macro where no one can change it. Remember just because you don’t need it does not mean that you can’t set one up. I always run a tool change macro even if the machine does not require it.
    Glad you got it running. What parameters needed to be set?
    Stevo
    Sep 2008
    67
    Re: Leadwell MCV-OP with Fanuc Series OM missing O9001 macro
    Hallo
    i have mailing machine LEADWELL MCV-OP WHIT FANUC OM
    I NEED PARAMERES DIAGNOSTICS AND MACRO PROGS
    THANK YOU TO SEND IT Me by email:[email protected]
    May 2015
    12
    Leadwell MCV-OP with Fanuc Series OM missing O9001 tool change macro program
    Please send me through mail
    [email protected]
    Please help
    Aug 2011
    2517
    no one has it. anyway, it's already stated above you don't need the macro to make the machine work.......
    May 2015
    12
    Ok thanx for reply
    Sep 2008
    67
    Hellow
    on my mcv-op a spindle amplifier has à pcb a20b-1003-0920 lose paramètres
    if any one have a setting manual or paramètres help me m'y email:[email protected]
    thanks
    Dec 2009
    953
    for helping you we need the code of the motor not of spindle amplifier.
    May 2015
    12
    Dear how to backup I don't know if you know please tell me
    Feb 2013
    151
    Tnc,
    See post #4 here: http://www.cnczone.com/forums/fanuc/...s-fanuc-o.html . Log in and down load the pdf, it has the instructions for Om.
    Charles
    May 2015
    12
    Thanks for reply
    Sep 2008
    67
    Quote Originally Posted by zavateandu View Post
    Hello
    The motor mod:8P/8000
    Type:A06B-0725-b194
    3.7/5.5Kw 15/23Apm
    RPM:750/8000
    Thank you.
    Sep 2015
    4
    Hello
    Please tell me where i can find for leadwell fmc op with fanuc 0m diagnostic parameters.
    May 2015
    12
    PLEASE SEND ME YOUR EMAIL ID I WILL SEND U ALL PARAMETERS
    TNCNCHUB
    Sep 2015
    4
    Quote Originally Posted by tncnchub View Post
    TNCNCHUB
    [email protected]
    Thank you!
    May 2015
    12
    PLEASE CHECK YOUR EMAIL
  1. Replies: 4
    Last Post: 12-24-2015, 05:33 PM
  2. FANUC I SERIES, Macro?
    By BOATDUDEGUY in forum Fanuc
    Last Post: 10-24-2013, 11:07 PM
  3. LeadWell MCV-760 FANUC 0-MF ATC macro
    By cnc35 in forum Fanuc
    Last Post: 08-05-2013, 08:44 PM
  4. missing or copied programs FANUC series oi-TC
    By CNCmachado in forum Fanuc
    Last Post: 02-18-2013, 03:17 AM
  5. Leadwell MCV-550 toolchange macro
    By gbowne1 in forum Fanuc
    Last Post: 02-19-2012, 11:00 PM
