im having trouble aligning a turret on this lathe.I have aligned the turret several times at previous employers without any problems but this one has me stumped.it is a sl40 with live tooling and a vdi turret.the turret is round and not hex shaped so im assuming it is an older machine.the vdi pockets are oblong and not round so I cant indicate the pocket.i am putting a 1.25 round toolholder in each pocket and indicating the hole in the center.i can get the station im on to read 0 all the way around by loostening the face bolts in the turret and tapping the turret radially.when I go to other pockets though it doesn’t seem to stay at 0.some pockets I can correct by moving the x in or out but some are still out up and down as if I still have to move it radially but ive already set it for the 1st pocket I checked.
Here are the #s im getting
These # are the best I can get each centerline.
#1 x 32.3336
#2 x 32.3386
#3 x 32.3376 out .004 total up and down (not able to correct in x)
#4 x 32.335 out .004 total up and down
#5 x 32.3336 out .008 total up and down
#6 x 32.3296 out .006 total up and down
#7 x 32.3306 out .004 total up and down
#8 x 32.3286
#9 x 32.3289
#10 x 32.3317
The face of the turret and the spindle alignment look good within specs.
I seem to be able to get a pocket to read 0 all the way around without having to remove the brass plug and rotate the "inner" coupling.
Any ideas?????
Mark
Ps
The machine has been running fine but recently we had a job the required holes drilled +- .001 from centerline and we could not hit it.
