587,040 active members*
2,860 visitors online*
Thread: Gecko G540
    Mar 2010
    Gecko G540
    Hello
    My question is for all the Gecko users. I want to use the G540 stepper drive and the source of step and direction is a ControlLogix PLC.
    1.Would a 48V, 10A power supply be good enough for the G540.
    2.I am not using a Mach3, so can I can give the step and direction signals directly to the terminals 2 to 9 at the DB25 parallel port at G540.
    3.What exactly is fault mode that is mentioned in the setup guide.
    4.What are the maximum no. of connections that can be made at a particular terminal
    Nov 2008
    54
    Quote Originally Posted by Deb.bosch View Post
    Hello
    I can answer the first question. Power supply for the G540 has to be between +18V and +50V DC and a current rating of 2/3 times total current rating of stepper motors with max of 3.5A per motor. Your power supply works and can handle four 3.5A motors. Pick motors with a winding inductance of 2.5 to 3.0 mH per phase for maximum speed.
  1. gecko g540 on a lathe ???
    By Bennyboyz777 in forum Mini Lathe
    Last Post: 03-06-2010, 12:37 PM
  2. ZAY7045 + Gecko G540?
    By clocker in forum Benchtop Machines
    Last Post: 01-14-2010, 03:48 AM
  3. Gecko G540 Relay Help
    By The CNC Man in forum Stepper Motors / Drives
    Last Post: 12-03-2009, 11:11 PM
  4. Gecko G540
    By rotger in forum Servo Motors / Drives
    Last Post: 06-02-2009, 06:43 PM
  5. gecko g540
    By Teyber12 in forum Benchtop Machines
    Last Post: 05-31-2009, 08:23 PM
