586,443 active members*
3,204 visitors online*
    Dec 2006
    85
    Constant Velocity problem with 4th axis
    Hi!!! When I use 3 axis everything goes good and not jerk movements and vibrations appears using "Constant Velocity" for angles > 170°. When I use rotary axis and Z axis working at the same time it goes bad, It seems to be working with "exact stop" mode. ¿What is the problem?? (I tried to change 4th acceleration settings and nothing got better.)
    Regards
    Tiwanacote
    I don't think that Mach takes the 4th axis into account for CV mode, so there may not be anything you can do.
    Dec 2006
    85
    Thankyou Gerry!! I will confirm that Hypothesis
  1. Constant Velocity settings
    By Ranscon in forum Mach Software (ArtSoft software)
    Last Post: 09-03-2009, 01:08 AM
  2. constant velocity help
    By shnitzel in forum Mach Software (ArtSoft software)
    Last Post: 01-03-2008, 03:10 PM
  3. Constant Velocity Mode CONSTANTLY DIES!
    By backlashphoenix in forum Mach Software (ArtSoft software)
    Last Post: 05-21-2007, 12:52 PM
  4. constant velocity and power settings in mach3 plasma cutting
    By Knut in forum Waterjet General Topics
    Last Post: 09-28-2006, 04:19 AM
  5. A Axis Constant Rotation
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-22-2006, 03:57 PM
