Originally Posted by
hemsworthlad
Good point and let me tell you because it's just happened to me.!. . If the wire breaks and shorts to the spindle body it destroys winding in the spindle also in my case it damaged the vfd, it wont come out of fault now and so obviously as fried a chip or something.
The VFD is a good quilty make ABB German made and even thou well out of warrenty (2yrs) i've spoke to ABB and they will repair it for a minimal fee.
This high lights the point why to buy the VFD local and good quality brand.!. . If this had been the Chinese VFD it would be toast and I'd be out of pocket big time.
On the plus side (thou no consolation) after nearly 3yrs of hard use I was pleasantly surprised how good a condition the spindle was in when striped down, also very easy to strip and replace bearings if needed.
Also let me point out this damage was solely caused by my own hand because I had removed the spindle a few days before to test on on another machine and not replaced properly the cable holding clamp that supports the cable before the spindle connector enters motor so it was free to flex side to side, this is what caused the magic smoke to appear. ( BOY was it a big "brown pants" flash bang . .Lol)
Don 22awg is too small IMO 18 or 20 would be best, I use 18. Yes it's a pain in the Arse to fit in the cable clamp and I had to strip back some of the outer sleaving. To help give back some support and tidy the look I used some large heat shrink which covered everything nicely, Also It's important as you can see from the above comments that you have a cable support clamp a few inch's before the spindle else your open to stressing the cable.
Regards spindle grounding just run a wire from the spindle bracket to your main ground point.
Depending on the VFD the ground is often the frame bracket where you clamp the cables and you just connect the ground wire to a point on it. . . . I have 3 VFD's and thats how they all do it. . . Also the cable sheild grounds to this bracket on my VFD's.
Hope this helps.
