586,108 active members*
2,978 visitors online*
Page 54 of 63 4445253545556
Results 1,061 to 1,080 of 1243
  1. #1061
    May 2010
    44
    Re: Electronic home switches made easy!
    Look for shieled four core . those are shielded two core. You need power plus signal. ( 3) with the shield going to chassis ground.. Ideally
    Sent from my Vodafone 875 using Tapatalk
  2. #1062
    Jan 2013
    116
    do you have any link to some cheap somewhere? every place I look wants crazy cash for shielded wire.
  3. #1063
    May 2010
    44
    Quote Originally Posted by nekidfrog View Post
    a quick look on ebay
    Blue Canare Quad Core Mic Microphone Cable L 4E6S 06 by The Foot | eBay
  4. #1064
    Apr 2010
    486
    I sell a lot of shielded wire for a special purpose. I buy big rolls from John's Wire Shop, on eBay.
    Although he typically lists 50 ft and 100 ft lengths, he'll gladly sell you 1 ft, or whatever length you need. Nice guy to work with.
    Tom
  5. #1065
    Jan 2010
    44
    Hey Guys,
    Now I'll admit that I haven't read all 36 pages of this thread, so if my question has come up before, please excuse my laziness and point me to the appropriate post.
    I bought a linear slide table that has hall effects sensors already installed, but no documentation about which wires are +5v, grnd, nor feed. How does a guy with only a VOM, a 5 volt DC supply, and an LED go about detecting which is which?
    Thanks very much in advance,
    Gary
  6. #1066
    Dec 2003
    24221
    Any numbers or? on the sensors, what are the wire colour, they are often standard.
    Al.
    Albert E.
  7. #1067
    Apr 2010
    486
    I've nothing against hall effect switches, but must point out one possible failing here.
    This design is fine for a homing switch, but has a limitation when used as a limit switch.
    Good safe design on limit switches suggests that ALL the wiring on limit switches and the emergency stop switches be wired in series. This means that a broken wire or a loose connection anywhere in the system activates the emergency stop feature.
    Don't remember all the references (or even the correct wording) here, but there is an (probably an OSHA) rule that requires a machine to be able to shut itself down and cease all movement (including the spindle rotation) when certain events might occur.
    There is a lot of wiggle room in this rule. For instance, a small mill, like a Sherline, for example, has steppers that are weak enough so that they just stall when the physical limits are reached. So there are no limit switches installed, and generally not even a physical eStop button.
    As machiines get bigger and heavier and faster and more powerful, the rules should be read more as hard guidelines.
    As I have absolutely no idea what type of machine any of you are building, I can make no specific suggestions. But do attempt to wire your limit switches in series whenever possible.
  8. #1068
    Jan 2010
    44
    Al,
    The wires are black, light blue, dark blue, and red as you can see in the pictures.
    There seems to be a sensor at each end of the slide.
    I did search the website of the manufacturer, but couldn't find anything.
    Thanks!
    Gary
  9. #1069
    Dec 2010
    313
    Quote Originally Posted by GEBrown View Post
    Hey Guys,
    Gary
    Look for the resistor!!
    The hall effect sensor needs to be pulled high or low, at least knowing where the resistor is helps you find the Output pin.
    Also the Hall effect sensor is more for position sensing not limit sensing, Opto's are great and a mechanical switch works good too.
    Hope that helps!
  10. #1070
    Jan 2010
    44
    crob09
    If by "look" you mean visually look, the pictures show everything I can see. The sensor is built into the table and I'm leery of pulling up on the sensors themselves for fear of impeding the travel of the table.
    Now if you mean "look" with a VOM, I'm all eyes (ears).
    I use optical switches normally, but since these are built in, if I could learn how to wire them into a Gecko G540, I'd have another option to look at. At least I will have learned something new.
    Thanks all.
    Gary
  11. #1071
    Nov 2011
    10
    I have ordered the wrong sensors by mistake, and I am really happy about it!
    I have ordered the SS411A, which is the bipolar version of the hall sensor. In other words, the switch needs a S > N magnetic field transition to work. So instead of presenting the S face of a magnet, I presented the side of a tiny (4x4x2mm) NdFe magnet.
    With a SS441A, the whole magnetic field has to move by the sensor, and for a small mill like mine, this costs valuable millimeters. In my setup, the S > N transition takes place in 2mm. And that is perfect for me.
    Just wondering if any of you electronic gurus see any downside using a SS411A?
    Thanks a ton,
    Pleine
    Lathe: Hobbymat MD65, Mill: Sieg SX2, Mill: Taig CNC MiniMill, Hammers: many
  12. #1072
    Dec 2010
    313
    Yup I mean look for the resistor.
    Don't pull on things, but find the resistor and you'll find the output wire, it's that simple.
    Opto's wire the same way a mechanical limit is wired, Gecko drivers should have silk screen to help with that step.
  13. #1073
    Feb 2014
    103
    Alright got mine working. Almost. Everything is repeatable except the z axis. I slowed it down to 20% speed. Still position is off by a mm or so. Any ideas as to what is happening or what I can try.
  14. #1074
    Jan 2012
    28
    Steve,
    my homing settings are
    X 20pct of 750 = 150, air gap is 1/16
    Y 10pct of 750 = 75, air gap is 1/16
    Z 60pct of 31 = 18, air gap is 1/8
    Haven't checked it in a while but was only .001 sometimes, mostly zero.
    picture is my Z axis homing setup. The white disk has the magnet in the center flush to the surface, the black speck in the very center of the pic is the sensor. This pic is after a Z homing command.
    Move each axis to near home press the arrow/pgup/dn key to move away at 100 pct, look at the velocity reading in mach3. Look at the pct in homing page.
    I did use 1/8 super magnets for accuracy, seemed to pay off.
    Jack
    Quote Originally Posted by Stevos758 View Post
  15. #1075
    Feb 2014
    103
    My bad. I meant x axis. I miss typed on my phone. I'll get a pic of my setup later.
  16. #1076
    Feb 2014
    103
    Quote Originally Posted by hollisin View Post
    Steve,
    Jack
    Let me be more clear.
    All axis home properly, All axis except X are perfectly repeatable. I am picking a spot on the opposite side of the table and using G00 to move it there to visually check accuracy. The Y axis movement ends up going to the same spot every time. The X is off by a MM or two in random directions each time? It will never go back to the exact same position even though I keep using the same G00 command(examle G00 y-500 x-320)
    The only thing I can possible come up with is there is a capscrew right next to my Hall switch. Could this somehow throw off the magnetic field?
    I cant wait to get this working! Hopefully someone here can help.
  17. #1077
    Feb 2005
    829
    Super magnets actually make the HAL sensor work less reliably.
  18. #1078
    Feb 2014
    103
    I see. I'll see if a smaller or regular magnet solves the issue.
  19. #1079
    35538
    I use a strip magnet, which is very weak. It needs to be very close to the sensor (<1mm), but works very well. Also, the sensor detects the magnet from the South pole I think. The strip magnet works well for this, as one edge is S, and the other is N.
  20. #1080
    Feb 2014
    103
    I did get it working. I needed to use 550ohm resistors instead of the 2.2k. They work fine now.
    I just need to figure out how I want to perm mount them now.
  1. Replies: 3
    Last Post: 11-05-2013, 02:54 AM
  2. Home made electronic for Spindle control
    By dinko in forum CNC Machine Related Electronics
    Last Post: 05-31-2012, 02:52 PM
  3. Auto backlash sensing with electronic home switches!
    By RomanLini in forum Open Source CNC Machine Designs
    Last Post: 11-14-2011, 02:36 PM
  4. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  5. Home made CNC mill (and some products made by it)
    By gcamlibel in forum DIY CNC Router Table Machines
    Last Post: 04-05-2004, 11:54 PM
