586,111 active members*
3,389 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Will these motors work with this controller
Results 1 to 6 of 6
    Oct 2009
    56
    Hi guys i'd like to ask if these stepper motors: http://www.mpja.com/prodinfo.asp?number=17757+MS
    will work with this controller: http://cgi.ebay.com/3-AXIS-CNC-ROUTE...#ht_5909wt_989
    I already have the motors but i'm looking for a controller for them.
    Ohh and if anyone can find out the torque of them.
    Thanks.
    Oct 2005
    2392
    Those motors are quite small, 12v 250mA unipolar with 6 wires.
    The driver is a bipolar driver that will work up to 2.5amps, but fortunately your motors can be wired as bipolar too.
    It should work, and the driver has a lot of extra capacity so you would be able to upgrade to bigger motors later and still use the same driver.
    Oct 2009
    56
    Quote Originally Posted by RomanLini View Post
    Thanks for answering. that helps me alot so i wont have to worry about them not working.
    my cnc maching that im building is quite small it should need about 50oz. of torque so i hope these motors are that big but i do have some on ebay that are 80oz. so if these arent big enough i'll get those .
    Aug 2009
    392
    Just a little input quickly. MPJA is a surplus distributor; this means if an item is out of stock (which those motors are), generally they are for good. There are a few decent motors on MPJA besides the one you posted that are quite cheap (generally around 75-130 oz-in), as well as lots on www.alltronics.com. Good luck!
    Oct 2009
    56
    Quote Originally Posted by Jesse B View Post
    Aug 2009
    392
    Quote Originally Posted by purecnc View Post
    No worries
  1. How do I work out what motors I need
    By Methias in forum Stepper Motors / Drives
    Last Post: 07-02-2009, 02:36 PM
  2. How do Servo Motors Work?
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 06-06-2009, 06:00 PM
  3. Will these motors work with any hobby controller board?
    By stabbs in forum DIY CNC Router Table Machines
    Last Post: 12-28-2008, 11:45 PM
  4. Will these motors work for a router?
    By sanjiv in forum Stepper Motors / Drives
    Last Post: 08-15-2006, 04:51 PM
  5. Will These Work (Stepper Motors)
    By Hawkeye in forum DIY CNC Router Table Machines
    Last Post: 12-06-2003, 06:53 PM
