586,108 active members*
3,013 visitors online*
Results 1 to 7 of 7
    Mar 2010
    WTB: 3D scanner
    Hi Everyone,
    New here, looking for a 3D scanner, handheld unit if available...contemplating a Nextengine unit to hold me over till I can find a handheld 3D scanner.
    Using it to measure various automotive related OEM parts to establishment car fitment(s), render to solidworks and modify for our usage.
    So, if you have anything let me know via PM.
    Sean.
    Apr 2004
    5737
    I'm not sure the NextEngine will do what you want
    I think they work pretty well for small items that can mount on the turntable, but they aren't something you can just wave around in the air and capture good data with. And Solidworks, while it's a good program for designing parts from scratch, can't do much with imported meshes, which is what scanners typically deliver. If the parts you're scanning are relatively small, a Roland turntable-type laser-scanner might work - the work envelope on the LPX-600 is 9.5" diameter by 16" H. If they're larger, then a hand-held scanner like the UniScan from Creaform (which we also sell) is probably your best bet.
    To reverse-engineer a mechanical-type part from scan data, you want something like Rapidform XOR in between the scanner and Solidworks - that allows you to recover "design intent" - clean geometry instead of the rather noisy meshes that scanners produce.
    Andrew Werby
    www.computersculpture.com
    Quote Originally Posted by c.my.m3 View Post
    Hi Everyone,
    Sean.
    Mar 2010
    Thanks for the info and help Andrew, I contacted them this aft and got a quote for a full system...
    What has been scanned in the past for me was done with a Creaform Revscan, not out of necessity but it was what the shop uses. Here is a sample of the largest piece I would ever have to scan. Rough dimension is 4 feet by 1 ft
    Is it even feasible with anything less than a handheld unit like a Zscan or Creaform.
    Quote Originally Posted by awerby View Post
    Andrew Werby
    Feb 2010
    3447
    Talking
    I almost bought one (but spend the money on a tig welder first opps), YOU need to purchase "rapid works" with it to import models into soldiworks and be able to use the feature tree.
    https://www.nextengine.com/indexSecure.htm
    GO to "BUY" then click on the "rapid works image", now click on "rapid works" once again, then in the upper hand right corner click play demo movie. For the price there is NOTHING that comes close to the scanner with that software. I've seen one work in person and they are VERY VERY NICE! Unless you have 25grand+ this is your best friend
    A local autobody shop uses one on a home made Steady-cam setup. Instead of a camera they mount the laser scanner and instead of holding the unit it has about 8 adjustable legs like a spider that can hold the scanner in any position while it scans. Just scan and mesh the scans together. I will buy one as soon as i have the money for one again!
    Hi Everyone,
    Sean.
    Feb 2010
    3447
    "To reverse-engineer a mechanical-type part from scan data, you want something like Rapidform XOR in between the scanner and Solidworks - that allows you to recover "design intent" - clean geometry instead of the rather noisy meshes that scanners produce. "
    Buy the Nextenginer scanner + rapidworks XOR + HDPRO
    all can be purchased through Nextenginer under the buy tab.
    I hope to get one by fall.
    Feb 2007
    198
    hey diyengineer
    I have a nextengine scanner but don't have the $ for rapidworks software. if you buy me this s/w i'll scan stuff for you for the rest of our lives!
    -jim
    Feb 2010
    3447
    Quote Originally Posted by jimiscnc View Post
    -jim
    I don't have the cash for it at the time, either this fall i hopefully will. I have been trying to source a "copy" on pirate bay but no luck.
  1. RFQ 3d scanner
    By ssrmr2 in forum Employment Opportunity
    Last Post: 06-03-2008, 08:45 PM
  2. new scanner
    By nervis1 in forum Digitizing and Laser Digitizing
    Last Post: 12-12-2007, 12:02 AM
  3. Scanner 3d con leche.
    By granado in forum Spanish
    Last Post: 07-09-2007, 08:56 PM
  4. scanner
    By bruha in forum Mastercam
    Last Post: 01-18-2007, 04:11 PM
  5. Scanner to Cad?
    By Cold Fusion in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 07-30-2005, 04:31 PM
