586,119 active members*
3,510 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Attempting to learn Madcam
    Feb 2010
    I thought I would try something simple just to see if I could produce usable code.
    Particulars:
    Cutting a cylinder out of a block.
    Both cylinder and block are centered around the X axis
    Post processor is Mach3_inch_4-axis
    The toolpath that I get cuts the lower 3/4s out leaving no toolpath from 315 degrees around to 45 degrees.
    Any hints?
    Mike
    Jun 2003
    2103
    Hi Mike,
    From looking at the bmp, it almost looks as if your rotational limits are set for less than a 360 rotation. Can you check that and see if that is the case?
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jun 2003
    2103
    I just talked with Joakim about this issue and he informed me that this was in fact a bug that has been fixed in service release 2.
    Mike
    Feb 2010
    Thanks for the reply!! I just downloaded SR2 and it did solve my problem.
    Now back to that learning stuff...
    Thanks again
    Mike
  1. Learn IGF One touch or Learn a CAM?
    By brettcnc in forum Okuma
    Last Post: 05-08-2012, 02:37 AM
  2. USE MADCAM WITH MY EDM???
    By Steve.B in forum Waterjet General Topics
    Last Post: 01-22-2010, 07:08 PM
  3. Replies: 11
    Last Post: 08-24-2009, 08:14 PM
  4. New US rep for Madcam
    By turmite in forum News Announcements
    Last Post: 07-08-2007, 01:14 AM
  5. Attempting to modify datain/out parameters
    By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-01-2006, 01:23 AM
