586,080 active members*
3,475 visitors online*
Results 1 to 11 of 11
    Feb 2006
    49
    want to cut .005 in. stainless with cheap laser
    I need to cut .001 to .005 in. thick stainless foil to make parts about 1 in. square and wondered if there was a cheap laser (<3k$) that could do the job. It can run slow since these are prototype parts.
    I can build my own system if need be since I have I have x y tables and motion control hw on hand. I read that the cheap Chinese 80w CO2 laser tubes will not cut metal, but is that true even for thin foil? Are there any other sources of non CO2 lasers in my proce range that that would cut foil?
    Thanks in advance for your help.
    Doug
    Atlanta, GA
    Dec 2008
    1258
    Doug,
    Yes, sorry but that is true even for thin foil. The wavelength is just not suitable.
    What you need is a low cost Nd:YAG or Yb:YAG fiber laser, look for a surplus medical laser or buy a pump diode and make your own.
    Zax.
    Feb 2006
    49
    I searched ebay for yag lasers and noticed lots of small cheap ones for tatoo removal. The plse rate only goes up to 5hz, so I guess that's too slow, but do you think they might work.
    Laser type
    Q-swiched Nd:YAG
    wavelength
    1064nm/532nm
    Pulse Energy
    400mJ~1100mJ
    Pulse Duration
    ~10ns
    Pulse rate
    1,2,3,4,5Hz
    http://cgi.ebay.com/PRO-Q-SWITCH-YAG...item3efe0aed4b
    Doug
    Dec 2008
    1258
    Doug,
    10ns pulse duration at 5kHz, with a maximum power of 1.1J (that's if it can even deliver max power at max duty cycle - maybe not) isn't even close to the power you need.
    Look for a Ytterbium laser (marking system) on the surplus equipment sites, they come up now and again within your budget and worst case you'll have to drop a couple hundred bucks on a new pump diode.
    Zax.
    Feb 2006
    49
    Would this laser IPG 100w DLR-100-AT I see on ebay be a better choice and able to cut the .005" stainless steel foil?
    http://cgi.ebay.com/NEW-IPG-Photonic...item27afe52226
    Thanks for the advice.
    Doug
    Apr 2007
    327
    A quick google search brought up their website and a pdf with the specs. Here is a link: http://www.ipgphotonics.com/Collater...DLR_Series.pdf
    It's not a metal cutter either.
    Quote Originally Posted by wddanie View Post
    Doug
    Dec 2008
    1258
    It should, but depends on the final optics. Based on the description it may have a longer DOF for heating rather than cutting. I would suggest checking with the manufacturer, especially for a new unit at that cost.
    Zax.
    Mar 2010
    Google YAG, saw http://www.tradevv.com/chinasupplier...r-cutting.html
    It applicable various metals, alloy and so on. Is that you want? But YAG seems not cheap.
    Sep 2008
    117
    Doug, I don't mean to be rude, but you need to lsiten. You need a YAG or Fiber laser to cut metal. A CO2 laser operates in about the 10.64 microns wavelength, a YAG operates at 1.064 microns (10 times shorter) and that's how it can cut metal.
    A CO2 laser can be made to cut metal but at huge power ratings, starting in the 2,000Watt range and prices start around $200K.
    Currently there are no cheap YAG lasers as they are not as popular as the CO2. Today a "cheap" used YAG starts around $20K, if you are lucky.
    What are you trying to do? How many parts do you need to cut? How big is the part?
    There are better ways.
    Laser Help
    Doug,
    All these guys have given you the right answer. You need YAG or KiloWatt CO2 to cut metal. Pulsed YAG cost $40K+, and Kilowatt CO2 cost $250K+.
    The IPG laser you looked at will not work, you need pulsed YAG.
    If you only need to cut several pieces, I can manage to get it done for you free of charge. 0.001 - 0.005 is not a problem, I have cut 0.070 stainless steel with our small 20Watt YAG Laser.
    Peter
    Mar 2010
    Hi, Doug,
    A yag50w laser or a 10w fiber laser can do that work.
    Fiber laser can have more good cutting effect.
    We also have co2 laser, 60w,80w,100w, we can do some test on our machine. You can inform me your material details if you like.
    kind regards,
    Ms.June Zhu
    www.zhongtailaser.com
    [email protected]
    mobile:86 18607188502
  1. Laser Cutting Stainless Steel ???
    By Babba in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-04-2015, 06:45 AM
  2. Laser suitable to engrave stainless steel?
    By el_tony33 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-17-2013, 06:48 AM
  3. Marking Stainless using CO2 laser 60 Watt
    By Huahahahahaha in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-06-2010, 02:10 AM
  4. RFQ laser cutting 22GA stainless.
    By nate in forum Employment Opportunity
    Last Post: 04-10-2009, 05:10 AM
  5. what is the Best Laser cutters up to £15,000 for cutting stainless steel?
    By Paul Shroom in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-24-2009, 03:17 PM
