I'm in the process of getting an XYZ 1010VMC 4 Axis mill up and running with CAM. I'm testing it with GCode I export from SolidCAM. I just made a first component, and can see the process will work. Up to now we've been working in Shopmill on the machine on steel components.
So now I want to test HSM operations on aluminium (4"x4"x2" block). I have a carbide 10mm finishing endmill with 3 flutes and cutting length of 22mm. I'm thinking of roughing at a spin rate of 200m/min (6400 rpm - my maximum is 8000rpm on the machine), at a Feed of 0.06mm/tooth (1140mm/min). The step down will be 3mm.
I've already tested this tool with these settings, but at a step down of 2mm. Seemed to do a good job. Does this sound reasonable?
What is recommended for coolant on such work? Any info will be much appreciated.
Goor
