586,393 active members*
2,787 visitors online*
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Aug 2016
    Re: #2018 Turret Run Alarm (A4.2)
    clap clap clap, you are a genius, you are the messi of the cnc. thank you from Argentina!!!
  2. #22
    Aug 2016
    Quote Originally Posted by firekoe View Post
    Happy to help you keep your chips flying.
    my post is for you man! thank you
  3. #23
    Oct 2016
    Need your help:
    We have GOODWAY GLS 200 CNC machine and want to adjust the zero point the turret .... but the problem is when we try changing relay No. 7 bit No. 5 to 1 (Turret JOG Mode) a message appear "write protected" and the value of the bit never changes to 1. can anyone help me with this problem...thanks
  4. #24
    Dec 2009
    957
    Quote Originally Posted by ahmedaboueid88 View Post
    Need your help:
    did you changed the PWE to 1?
  5. #25
    Sep 2013
    A big thank you from Russia!!!! :cheers:
  6. #26
    Oct 2016
    thank you Mr zavateandu for your replay ... I changed the PWE to 1 and it worked with me
  7. #27
    Nov 2019
    Quote Originally Posted by Ahmed18 View Post
    I know the Instructions
    1- Keep-relay No. 7 bit No. 5 must be 1 (Turret JOG Mode)
    2- Change to Handle Mode
    3- Feed HOLD + Spindle STOP
    4- The turret will unclamp
    5- Click on the +X and -X to rotate the Turret
    My problem is at step number 5 cuz the turret doesn't rotate
    So how did you able to fix this problem?? because I'm currently in the same situation.
  8. #28
    Dec 2009
    957
    if the turret is not rotating it means that or is not unclamped by hydraulic cilinder or is unclamp but the sensor that should see it ,is not working.
    check in diagnose the input for the sensor if it is going from 0 to 1,if not,try to adjust the sensor or replace it if is broken.
    the turret will rotate only if the cnc see the senor for unclamp in 1 position ,otherwise will not rotate.
  9. #29
    Apr 2020
    Salut monsieur
    Est ce que tu peut m'aider. J'ai une machine goodway avec une erreur a4. 2 turret run error. J'ai essayer de zeroter la turret mais en vain merci pour votre aude
  10. #30
    May 2020
    how to fix this alarm sir
  11. #31
    Feb 2022
    Please send me the procedure i have the same problem on my cnc lathe goodway
  12. #32
    Feb 2022
    Can you send me the procedure
  13. #33
    Sep 2022
    it turned out that the batteries where died and i need to replace them then index the turret if anyone needs the order of operation to do this i have it now as i could not find it in the book so just post if you need help with this problem
    Please I need this procedure. I know it's long period from the time you posted but I hope that pdf still around
Page 2 of 2 12
  1. Replies: 26
    Last Post: 03-02-2023, 11:25 AM
  2. NEED HELP! Kia SKT 28 turret alarm
    By Pyretta-Blaze in forum Hyundai Kia
    Last Post: 06-30-2013, 01:27 PM
  3. HELP QT 350 alarm code 371 turret servo alarm
    By kirkmach in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-19-2011, 09:39 AM
  4. Tool Turret Fault Alarm on TL-1 with no Turret?
    By Edster in forum Haas Lathes
    Last Post: 02-08-2010, 03:35 PM
  5. error code 2018 turret reference required
    By progeny in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-24-2009, 06:43 PM
