586,104 active members*
3,427 visitors online*
Thread: Work Offsets
    Apr 2005
    14
    Work Offsets
    I am new to MC. Trying to post some sample program to machine. So far I cannot figure out where in MC9 I can enter Work Offsets. I can add G54 manually to the program, but I would like know how to do it in MC. Can you guys help?
    Joe
    Apr 2003
    1876
    There's a few ways to do this in Mastercam. (That's a typical response for Mastercam related questions, because there's usually several ways of doing things)
    The easiest way is to open the operation and click T/C Plane button on page one of the operation dialog. To the left of the next dialog, check the box "Work offset", and enter a value for the offset you want.
    -1 = next available, (usually G54) This is the default value.
    0 = G54
    1 = G55
    2 = G56 etc.
    Another way is to create a WCS with an offset assigned to it. You can create any number of WCS, and assign different offsets to each. This is a more involved and dificult way, but is much better for bigger programs. (I often have up to and in excess of 150 operations per part, with up to 6 different offsets/WCS's, and the latter way is the only way to go on programs like that.)
    HTH
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2005
    14
    Thanks Matt,
    I really appreciate your help. Some day will tackle WCS. Not now as I have more 'gray' areas to work on them now.
    Joe
    Apr 2003
    1876
    No problem, Joe.
    It took me a while to get the WCS to work the way I wanted, but I'm sure glad I took the time to figure it out.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. CNC lathe tool and work offsets
    By mm4039 in forum MetalWork Discussion
    Last Post: 11-18-2013, 06:28 PM
  2. Setting Work & Tool offsets
    By Shizzlemah in forum Fadal
    Last Post: 04-16-2005, 06:04 PM
  3. Work Holding Methods
    By InventIt in forum DIY CNC Router Table Machines
    Last Post: 09-14-2004, 09:13 AM
  4. What is 2.5 d work
    By Patrick2by4 in forum DIY CNC Router Table Machines
    Last Post: 07-05-2004, 05:04 PM
  5. Down/up loading offsets
    By JPann in forum DNC Problems and Solutions
    Last Post: 03-22-2004, 03:17 AM
