586,069 active members*
3,749 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > anotehr possible way to replace the ball screw concept
    Jun 2006
    106
    I was holding a couple of roller bearings on a threaded rod while moving them to another location and when I took them off I noticed that the last one flipped sideways as much as it could and became stuck on the threads. so I tried turning the rod while applying pressure to this and I found that the threads actually hold true to the ridge or sharp corner of the inner race of the bearing. so I am wondering if this could be applied in a practical manner
    a simple way of showing this would be this
    the slash (/) is the bearing and the dashes (---) would be the threaded rod
    my idea is to turn several of the bearings in different directions and use a pair of plates with small curved grooves cut into them
    then the plates could be pressed together with a set of screws on the corners to apply the desired pressure( enough to make the edge of the inner race catch on the threads tightly but not bend the threaded rod)
    so in the end it would look something like this:
    __________________
    _|______________|_
    or this:
    __________________
    _|______________|_
    (ignore the periods as the forum would not let me string up a bunch of empty spaces
    has anyone already tried this?
    if so a link to their attempts?
    Feb 2007
    664
    sounds interesting
    Aug 2008
    573
    Bill
    Jun 2006
    106
    yup that was why I was asking. figured some one some where had to have thought it up and maybe the mechanics had been already worked out so I will not have to
  1. screw nut, bronze or delrin slide ... concept
    By turpija in forum DIY CNC Router Table Machines
    Last Post: 12-05-2009, 10:26 AM
  2. ball screw rebuild or replace Roboform 400
    By jetski in forum EDM Discussion General Topics
    Last Post: 08-07-2009, 02:33 PM
  3. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  4. Belts to replace long ball screws? What are your thoughts??
    By runinbymdnt in forum Linear and Rotary Motion
    Last Post: 02-17-2007, 11:31 PM
  5. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
