586,521 active members*
3,496 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA OSP READER v2.1
Page 1 of 2 12
Results 1 to 20 of 30
    Aug 2011
    419
    This is last version of OSP to PC emulator.
    FEATURES:
    -You can drag and drop files between OSP formatted floppy and PC (BB1 directory)
    -Initialize a floppy OSP Format
    -Backup and restore OSP formatted floppies.
    -Print file
    -Delete file
    -Protect or unprotect file
    -Compare files
    -View file on floppy
    -View and edit file on PC
    -Rename file
    -View properties of files
    etc..
    LİNK:
    okuma_osp_reader.zip download for free on file share letitbit.net
    Mar 2010
    72
    Re: OKUMA OSP READER v2.1
    Can anybody help me?
    I am new to okuma. I make a program ABC. MIN. I write M30 at the end of program. When I run this program it stopped at the end by M30. But now I can't run the program. When I select the program by pressing Auto mode>F1>*>select program >write. Then nothing happened. No program can run. Can anybody help me to fix this...?
    Aug 2011
    419
    Replace M30 to M02 and try again
    Mar 2010
    72
    Thanks for your reply. Yes I changed but this is not running. I select it from the list but it's is not selected
    Sent from my IM-A830L using Tapatalk
    Mar 2010
    72
    Program don't select and don't run
    Aug 2011
    419
    What is machine's name and which control unit?
    Mar 2010
    72
    Okuma & Howa
    Millac 6 VA
    1989
    Control OSP5020L
    OH-OSP-MG
    Please help me. I am so disappointed.
    How to activate .MIN file?
    Dec 2008
    3110
    Quote Originally Posted by cic108 View Post
    You need to read-up on how to create your own thread on CNCzone, not hijack a topic that has no relation to your problem ( it has nothing to do with an OSP reader or RS232 settings )
    Millac 6 VA......................this is a mill
    Control OSP5020L..........this is a lathe specification.....read the manuals......possible screen was replaced from a lathe.....I'd guess to is an OSP5000-MG or a Fanuc control
    correct procedure to selecting a program on OSP control
    AUTO mode
    - Program Select [F1] ...... > PS is on the lower command line
    - ABC(.min) <WRITE>
    the .min is a default setting and is not required to be typed. The program is parsed ( checked) that it meets certain requirements ie ends with an M2 or M30
    the program should then be shown as the current run program, or an alarm is displayed for if it was not selected
    To run that program, cycle start is then pressed
    Errors in programming usually show as an alarm, It gives a number with a seriousness rating ( A means very bad, D means you can still run the machine )
    - also it gives a description of the error.........this entire line is required to be stated to us for any possible solution
    A program not running can be any number of reasons
    - no movement commanded
    - feedrate &/or rapid over-ride knobs turned to zero
    - Single block is ON
    - unsupported G or M code
    - startup condition not being met. ie Doors closed, Fanuc controls require ALL axes to be homed
    Mar 2010
    72
    Sorry to all that I posted my problem in someone's post. I am very sorry because I am new to here and I don't know how to create my own post.
    Dear Superman. ... Thank you so much for helping me. My machine is a mill it has osp5020 control not a fanuc control. My program is OK. I ran this one time but when the last block M30 executed its stopped and the program is which name was visible on top middle of the screen suddenly hide. It means program was unloaded or deactivate. Now I try to open that program as the procedure that you said. Auto mode>F1>select program>write. But when I press cycle start, it doesn't execute and also I can't see the program name ABC. MIN at top middle of the screen.
    Do find what is the problem? Why the program is not activating and running?
    I'll be very thankful if anybody solve my problem. ..
    Dec 2008
    3110
    Unless it makes it back to the start of the program....it is not OK
    - activate a different program, then re-load the ABC program
    Did you type M3O (oh), instead of a M30 (zero) ?
    put up the last 10 lines of your code
    Mar 2010
    72
    It's OK now. Program is running. Thanks for your help. Now I have another problem that when I try to change the tool with M6. The tool orient and then stops responding. There is no tool change. Can you tell me what is the problem. Thanks
    Regards
    Dec 2008
    3110
    Regards
    What is the alarm you are getting ? ( the number & the full description )
    M6 by itself will do nothing
    it must be used to call-in a tool that is registered in the tool carousel ie T1 M6 , or be "pre-selected" beforehand
    Code:
    T1 M6       ( calls in T1 )
    T2             (pre-select T2)
    G0...
    M6            ( calls in T2)
    T3             (pre-select T3)
    G0....
    M63          (de-select the pre-selected tool, find empty pot )
    M6             (empty tool in spindle)
    Mar 2010
    72
    In MDI mode I sent a command M6T1. But it does nothing. I think there is a problem with the PLC of tool magazine
    Feb 2009
    6028
    Try t1 or a different tool, then m6. And make sure the z axis is up at the limit.
    sent from me
    Mar 2010
    72
    Yes. The tool orient then moves up to the limit then stops every thing. Magazine is not rotating
    Feb 2009
    6028
    It the tool pot in the down position? You should have a manual tool change recovery buttons on the front of the panel.
    sent from me
    Mar 2010
    72
    The tool pot is up. No tool rotation nor tool pot movement.
    Mar 2010
    72
    Can you help me to fix the magazine PLC. I think somebody change the settings of PLC. Because the numbers along with the tools are also looking disturbed. Three of them showing zero (0)
    Feb 2009
    6028
    No, something doesn't jive. No external PLC on a 5020, and your showing a build date of 1989, 5020 didn't come out till the early 90s.
    sent from me
    Mar 2010
    72
    I'll send you some pic on Monday so that you can find its model and type of ATC. Thank you very much for helping me..
Page 1 of 2 12
  1. OKUMA OSP Floppy Reader
    By erdemkaraman in forum Okuma
    Last Post: 08-10-2011, 07:39 AM
  2. btr reader
    By [email protected] in forum Fanuc
    Last Post: 02-02-2011, 04:45 AM
  3. OPTICAL READER
    By SNERLAND in forum Waterjet General Topics
    Last Post: 05-09-2009, 12:42 AM
  4. Okuma OSP 3000 tape reader
    By hsimola in forum Okuma
    Last Post: 04-01-2008, 04:37 AM
  5. Replies: 11
    Last Post: 08-15-2007, 09:06 PM
