586,111 active members*
3,724 visitors online*
    Feb 2009
    4
    TNC 530 USER NAME
    Hi!
    We are having a problem with Heidenhain TNC 530 installed in a milling machine, sometimes, when we started the machine, at the screen appears the following message
    USER NAME:
    before starting operating system.
    If we turn off the CNC and after turn on it, sometimes, the operating system starts, PLC compiles, etc; then we are able to work for a bit, but shortly after the following message appears:
    Fatal error child process termínate
    Process: soky
    Exit code: 3
    Detailed error Information has been stored to SYS:\soky.err
    Press END to reboot
    We are suspecting hard disk is damaged, but we are not sure. What you recommend us?
    Appreciate very much your help
    RVILA SPAIN
    Quote Originally Posted by rvila View Post
    Hi!
    USER NAME:
    Process: soky
    Exit code: 3
    Press END to reboot
    RVILA SPAIN
    Hi I know it's been a long while but what did you have to do to resolve this pr Home? I now have it !!
    Dec 2020
    Hi, will anyone of you could tell how to get out of this fatal error, child process termination on iTNC530 control
    Nov 2008
    69
    Re: TNC 530 USER NAME
    First of all, if you can, take a backup with a TNCremo.
    Then the harddisk needs to be changed.
    Jukka
  1. Replies: 2
    Last Post: 06-11-2013, 11:26 PM
  2. new user saying thanks!
    By revkev6 in forum Milltronics
    Last Post: 11-03-2009, 03:29 AM
  3. VCarve Pro user needs Aspire user help
    By ntww in forum Vectric
    Last Post: 10-08-2009, 03:08 AM
  4. New user...need help please
    By jaslep13 in forum Surfcam
    Last Post: 10-12-2006, 06:53 AM
