586,121 active members*
3,139 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > BMC20 & Ultimax II Backlash Comp
Results 1 to 18 of 18
    Feb 2010
    163
    Question BMC20 & Ultimax II Backlash Comp
    I hope you've enjoyed my saga with the BMC20.
    Before putting all the chip shields back on, I was doing some final checks to make sure the gibs & such were set nicely. I ran into something funny....
    First, the Y axis. It's perfect. Shoving the table around results in 1-2 tenths of motion, so the gibs are adjusted nicely. Checking for lost motion, which I did by putting a tenths indicator on the table, jogging towards the indicator a couple thou, then jogging away and noteing how much the control's position indication changed before the indicator moved resulted in about 4 tenths of "motion" from the control before the indicator moved. Perfect. (Remember that it's got 38,000 hours!)
    The X axis is a different story. Again, checking the gibs by moving the table showed 1-2 tenths of motion at one end and 4 tenths at the other. Good enough for a 20 year old machine.
    The lost motion check is another story. The same procedure, jogging the axis towards a tenths indicator, then jogging away, revealed that the axis moves smoothly towards the indicator, then when I reverse the jog wheel's rotation (to move the axis away) the axis jumps TOWARDS the indicator about 1.0 to 1.2 thou before moving smoothly away.
    When I invert the directions, ie, move away from the indicator then reverse to move towards the indicator, I get the same jump in the wrong direction before movement in the correct direction starts. I slackened the gibs & keeper plates with no change in results. I indicated the end of the ballscrew, and it doesn't move lengthwise enough to deflect the indicator at all.
    Then, I touched the timing belt while the axis was stopped. It's got a lot of miniscule motion going on even though the axis is stationary - it feels like vibration rather than actual movement. I presume this is typical, as the Y and Z axes do the same.
    While touching the timing belt I repeated the jog one way then jog the other, and I can feel the servo turning the wrong way for an instant on axis direction reversal before turning the correct way. It does this consistently. Thus, I don't think I have a mechanical lost motion issue.
    It sounds like (1) the servo needs tuning; or (2) the backlash comp is set wildly incorrectly; or (3) the axis acceleration is set wrong; or (4) something else that I am not familiar with.
    OK, my question: How do I set the backlash comp? I'd like to check what it is, at least. It's running Ultimax II V8.60. I tried all the secret screens that I know (102, 488, 642) and I did see axis acceleration values on 102 but not backlash comp. It was updated from V7.something (I have the old EPROM set), and the dual-axis cards have four, 8-position dip switches on them, and one 4-position dip switch. I haven't seen cards like this before:
    Of note, the machine was run for quite some time with the auto lube system inoperable. Well, there was one metering unit that worked on the Z ways. To compensate for this, the previous owners had upped the volume pumped by the auto lube pump to the highest value possible. This had no effect, of course. Presumably running with relatively dry ways required the backlash comp to be adjusted much higher? You'd have though they'd just fix the auto oiler.
    Jun 2008
    1104
    As you look at the board above, the backlash is set in two ways.
    The S3 switch does the Y axis on the X&Y dual axis and the S5 does X.
    On the Z&Spin card, S5 does Z.
    The switches add backlash comp from right to left as follows:
    sw8 0.000025"
    sw7 0.00005"
    sw6 0.0001"
    sw5 0.0002"
    sw4 0.0004"
    sw3 0.0008"
    sw2 0.0016"
    sw1 -------
    So if you find you have 0.00055" of backlash, use switches 4,6&7.
    It is also worth noting that backlash can also be entered on the leadscrew map. The best way of setting it up is to make the reverse map the same as the forward map then setting the backlash on the switches.
    To get to the map, calibrate the machine and go to toolchanger diagnostics. Enter 642 enter.
    As ever, note down as it is before changing it just in case you don't like it.
    Jul 2009
    71
    Bloke,
    I am firstly posting to express my admiration and appreciation of your understanding of these hurcos, and secondly, to make it easier for me to find this thread, when I need this information for my slv-40!
    Thanks again!
    -Parker
    Feb 2010
    163
    Hi Bloke, many thanks!
    One question, do you know what Position 1 switch does? You marked it with "----".
    Reason I ask, my X-axis has this position 1 switch CLOSED, while Y & Z have it OPEN.
    Also, my leadscrew map is all 0, forwards & backwards. Inside the electrical cabinet there is a sticker that says "Laser Compensation" and then has a bunch of numbers:
    Xaxis:
    LS .0007683$ (yes a dollar sign)
    BL .003349
    Motor Gap N/A
    The other axes have similar numbers. Can I back-calculate the leadscrew map from these?
    Aaron
    Jun 2008
    1104
    The SW1 setting I left marked ---- is for the backlash sign. Off will compensate for ordinary backlash, On will compensate for negative backlash. This is about the silliest thing anyone could include on a control. Just leave it turned off as it does nothing of any use (unless you are planning on taking your machine into space where the lack of gravity may cause problems)!
    The length comp works by using switches S2 for Y, S4 for X and S4 for Z.
    Measure the travel over 20" using a stack of slips. Note the error on the display (say, 20.0015") enter it on the switch for that axis (0.0015 equates to SW 3,4,5 & 6) Then add the sign bit on SW1 - On will shorten the travel, off will lengthen it. in this case, you need it to be off to make the table travel further.
    When done, you can store the switch settings in the leadscrew map by going into the map page and pressing "leadscrew map defaults".
    Feb 2010
    163
    Quote Originally Posted by bloke View Post
    Evidently this is the reason for the odd Xaxis behavior that I saw, the control is compensating for negative backlash. I'll adjust it and see what happens.
    Thanks for the note about leadscrew comp, I'll see what I've got for slip gauges (except we call 'em "Jo Blocks"). What was that about two countries separated by a common language?
    Oh, I presume that if my axis travels are less than 20" I can just scale the needed adjustments? Say, if I check over 10" and I find I need 0.0005 I can scale by two making the needed value 0.001" over 20"? (My Y is only 14" of travel).
    Thanks again,
    Aaron
    Jun 2008
    1104
    Yep, you can scale the figures to get the correct comp for the other axes.
    Aug 2007
    22
    Smile
    Hello. Excuse that I get and for that that not so on English. I too have bought recently for a hobby similar CNC in a faulty and bad condition. Back she has earned couple of weeks and there were problems. As on (HURCO BMC25 Board CRP2 Ver. 8.61 very ancient model) to work with the big operating programs. It can work in an additional load mode. At loading of the big program through RS232 loses touch when there are 10 % of free memory. At CNC 47Kb operative memory and additional FLASH 4xDS1235. On 128Kb. What format of the program is loaded through Floppy disk? What at floppy volume? (1.44 or 720) At program record in CNC on FDD, disk on PC it is not read. At CNC there is no system DOS.
    Jun 2008
    1104
    The NC through the RS232 will load until 10% free then it will stop. As you run the program it will dump out the beginning and start to load again until it has 10% free and will carry on like this until the program is completely loaded.
    The floppy has 720Kb capacity but cannot be used for NC file loading.
    Jul 2003
    71
    I found that replacing my Y axis drive belt solved my backlash problems on my BMC20. They do wear out over time.
    Aug 2007
    22
    Service Parameter Ultimax2
    Hello. I have BMC25 Ultimax 2. How it is possible to keep parametres CNC on a diskette?
    Where it is possible to take numbers and the description of parametres? I wish to increase a range of movement Z Axis. And to calibrate all Axis. I will be very grateful to you for any information.
    Jan 2014
    15
    Re: BMC20 & Ultimax II Backlash Comp
    Hello Bloke, I'm also want to express about my admiration of your experience and your answers. I have the same backlash problem but my problem is more complicated cause the backlash value in Y axis = 0.02", which is bigger than the amount of whole switches values together . so what do you think I have to do?
    I wish you could answer me. Thanks.
    Jun 2008
    1104
    You may have excessive play in either the axis drive belt, the angular contact bearings or the ballnut. Check also that the locknut for the axis bearings is tight.
    Jan 2014
    15
    Thank you Bloke, I'm going to check the points you stated for me
    1- Axis drive belt
    2- Angular contact bearings or the ballnut.
    3- The locknut for the axis bearings.
    and I'll give you the feedback after checking them
    Thank you for your response.
    Jan 2014
    15
    Hello Bloke, I want to thank you for your response I did as you told me and it looked like the problem was in the ballnut so I changed it and the machine has been ok
    But actually I'm facing now a new problem
    First the machine was working on a program and it had stopped in the middle suddenly !!!!. I restarted the machine but I found an alarm says :
    Leadscrew map checksum failed; data was invalid and it was erased
    and when I tried to make a machine calibration the axises position appears as stars not number like this:
    X ********
    Y *******
    Z ********
    so help me to figure it please
    Jun 2008
    1104
    Go to toolchanger diagnostics page.
    Press enter 6 4 2 enter
    When the hidden page appears, press the load defaults softkey
    Exit back to manual page
    Jan 2014
    15
    Thank for reply .I'm sorry but the page name is toolchanger or diagnostics, every time I go to this page he ask me (next tool), so could you tell me where I write (enter 6 4 2 enter) cause every time I tried to write enter 6 4 2 enter I couldn't write anything after 4
    I feel like I'm writing the tool number thank you I really need more clarification
    Jan 2014
    15
    thank you bolke alot alot alooooooooooooooooooooooooooot it works finally works you are greaaaaaaaaaat bloke
    but i need to understand what is that is that VODO hhhhhhhhhhh
  1. NOT A PEEP FROM RS232 PORTS ULTIMAX BMC20
    By LIVERPOOLWOODY in forum HURCO
    Last Post: 12-07-2012, 01:11 AM
  2. Replies: 5
    Last Post: 11-27-2010, 06:08 PM
  3. BMC20 / ULTIMAX 2 PROBLEM
    By theexhaustman in forum HURCO
    Last Post: 08-05-2010, 10:14 AM
  4. Hurco BMC20 with Ultimax 2 control
    By kwmkoester in forum HURCO
    Last Post: 04-30-2009, 11:52 PM
  5. backlash comp or not
    By woffler in forum Mach Mill
    Last Post: 04-19-2008, 08:54 AM
