586,104 active members*
3,403 visitors online*
    24221
    Cool Any Cheaper than this!
    Came across this while searching for Micro PIC's, looks like Hyperterminal is used to output a plotter file to a PIC.
    I though it might be of interest to someone.
    http://cstep.luberth.com/PStep.html
    Al.
    Albert E.
    Mar 2004
    142
    This is an attempt to create a serial stepper driver. This guy created a program that breaks down a hpgl file into commands that are sent to the pic which in turn creates a PWM signal for the steppers. This way you are not limited by the max troughput of the parallel port.
    EJK
    What goes down, should come up.
  1. THK Slide pack FBW? Cheaper linear system?
    By InspirationTool in forum Linear and Rotary Motion
    Last Post: 05-25-2005, 11:21 PM
  2. Ametek
    By guitars in forum Servo Motors / Drives
    Last Post: 04-21-2005, 02:12 PM
  3. Wire cutting big faceted shapes
    By terraswarm in forum CNC Wire Foam Cutter Machines
    Last Post: 02-10-2005, 11:53 PM
  4. Cheaper alternatives to SolidWorks?
    By dbassett74 in forum Uncategorised CAM Discussion
    Last Post: 10-14-2004, 07:14 PM
