586,104 active members*
3,403 visitors online*
    Oct 2004
    4
    Port setup emergency!
    Hello,
    We are trying to set up the computer using Kcam and Win2000. We're having trouble with figuring out the port, pin, bits. I can set something but then only the X axis to work or set a different way and only get the Y axis to work. Thanks in advance for any help, Stoene
    Feb 2004
    361
    here's the one I use on a hobby MDf router..
    what sort of problems are you having??
    Oct 2004
    4
    I tried it but it didn't work, any other ideas out there?
    Hello Vladdy,
    I tried your settings and they inputed ok but had no result. None of the output pins worked. I use the port view to see if anything is happening. Any ideas why nothing worked?
    I got 2 axis to work using this hack set-up
    port pin bit
    X step H37A 1 0
    Xdirection H37A 16 2
    Ystep H37A 17 3
    Ydirection H37A 14 1
    Any info is greatly appreciated, Stoene
    Feb 2004
    361
    You are probably better off rewiring from the parallel port to your controller cards, use either my example, or [probably better] the default setup in Kcam..
    You are using the strobe and select lines [1 / 17] as well as the auto and init lines..
    Better off using data lines 2 through 9 for step and direction control, and enable [if required]
    In mine I used 2,4,6 for direction,
    and 3,5,7 for step input,
    non inverted [or false] to indicate a postive pulse actuates..
    try 'pin setup, and base lpt1 address of &H378
    not that it won't work using your settings, but as 2 to 9 are output pins, and step / direction are output signals, I save the in/out ports for other thing like limit switches, or emergency stop buttons, etc..
    Oct 2004
    4
    got it working
    Hello Vladdy,
    Thanks for the info, I got the setup you suggested working. I'm not exactly sure what the problem was but it had to do with the OS. By going in and selecting lpt2 then back to lpt1 and also I went into bios and disabled serial ports it began working. Initially I could select H378 but it wouldn't work now it does. I won't look a gift horse in the mouth. But thanks again, your settings got it working. Stoene
  1. port setup for kcam
    By rcrabb in forum Uncategorised CAM Discussion
    Last Post: 04-12-2010, 02:30 PM
  2. Turbo CNC Not Running.... Setup?
    By Davedbq in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-04-2005, 08:20 PM
  3. Parallel Port Options
    By JasonCroyle in forum CNC Machine Related Electronics
    Last Post: 01-12-2005, 02:23 PM
  4. Taig CNC ready setup help??
    By efreak in forum Taig Mills / Lathes
    Last Post: 08-25-2004, 01:30 AM
  5. Using A Laptop Without Serial Port
    By mtech in forum Computers / Desktops / Networking
    Last Post: 08-17-2003, 02:58 PM
