Hi all,
I am machining a douzen of T nuts from a long flat steel bar and I was wondering if there were any milling bits specially design to cut (to detach each T nut once all machining an holes are done)
I guess I could use a end milling bit... but the smallest I have is 4mm, a lot of waste. And this doesn't give a very neat edge...
Note: The mill is manual, not CNC. End I can not use a sliding blade as the bar is too long to fit between the vice and the chuck.
Thank you,
RNR
