I've posted before looking for advice on this problem, the one axis stutters and shakes when jogging or when running a job, after a process of elimination of power supply, drivers, and mechanical, it seems the problem is in the controller itself. It is a DSP controller, I'm wondering if this is anything anyone has seen before (axis sits still and vibrates when jog buttons pressed, but when it kicks to high speed it moves smoothly in one direction until it reaches the switch)
And if there is a way to repair this, or if I should look at a replacement controller, and if so, what replacement? Since it's DSP and has an LCD control panel/buttons, what would be able to replace it?
tia.
Update: I've pulled the motion controller, it appears to be a mpc6515
